need help bad!!
Old Jun 3, 2014 | 09:35 PM
HarshMC's Avatar
HarshMC
6th Gear
Default need help bad!!
1990 sportster 883. bikes down man, turns over but wont fire getting gas, needles spitting it out, sparks are sparking trying to start.....wont, can spray ether in the carb will fire up HOT! and run full throttle only....any thoughts?
Old Jun 4, 2014 | 04:18 AM
Karate Dave's Avatar
Karate Dave
Talking
Sounds like the carb needs a good clean out. If it runs full throttle then the slow running jets could be blocked. Try stripping the carb and set it up properly.
Old Jun 4, 2014 | 06:26 AM
mrfikser's Avatar
mrfikser
also check that what you are seeing is actually gas and not water in the gas tank
Old Jun 4, 2014 | 08:29 AM
uncle kebo's Avatar
uncle kebo
Yep - both mentioned.. Sounds like bad gas and a dirty carb..
Mcnasby
May 7, 2013 03:20 AM
John7253
Exhaust System Topics
Jun 13, 2012 10:48 PM
JohnFlorida
Apr 26, 2011 02:33 PM
Chubbs103
Jan 30, 2011 11:14 AM
1989hd1200
Jun 1, 2010 04:41 PM
