2014 electrical problems
Old Jul 23, 2014 | 12:12 AM
AmberWhiskeyIron's Avatar
AmberWhiskeyIron
Default 2014 electrical problems
The bike has been taking 2 or 3 tries to start for a couple weeks now, but suddenly (thankfully at home) it won't start without a jump. If I try to start it without a jump it just clicks. I did try to charge the battery, and after it reached "full charge" on the charger I was using it will still only start while hooked up. It seems from a little research that it could be a relay problem? I have ridden a lot of miles in the rain and it seems corrosion on the relays is an issue. So the problem... I can't find the relays. Did some google image searches and the like but I can't find anything that looks like my bike under the left side cover. Can't find it in the owner's manual either.
Old Jul 23, 2014 | 04:09 AM
grbrown's Avatar
grbrown
Start by checking your charging system, including the battery. We have two Stickies in the Tech Electrical section that should help. Clicking relay suggests low battery, which may in turn be due to a charging problem, but also check for dirty (on a 2014?!) or loose main battery connectors. However if your bike is still under warranty.....
Old Jul 23, 2014 | 06:09 AM
Guzzi's Avatar
Guzzi
The bike has a warranty
....use it
Old Jul 23, 2014 | 01:04 PM
subguy's Avatar
subguy
The 2014 Sportsters don't have the fuse/relay box as the 2013 and below do so the rain issue is not a factor with 2014 bikes. I just "fixed" my neighbors heritage last night who was having the same issue. The battery had a good charge but the relay would click and the solenoid would click but not engage or turn the bike over. I jumped it and the bike would start. Removed the battery cables, cleaned them, but dielectric grease on the posts, cables and bolts and his bike started right up.
Old Jul 26, 2014 | 06:21 PM
Johhny51273's Avatar
Johhny51273
+1 on the loose battery cables. Had a similar issue with mine a few months back and turned out to be a loose cable.
sequel909
Electrical/Lighting/Alarm
Aug 3, 2017 04:00 PM
hdstevie
May 12, 2015 07:42 PM
Vic Bronco
Sep 21, 2013 12:07 AM
BadMetal705
Dec 23, 2011 02:18 AM
ranger007
General Topics/Tech Tips
Jan 23, 2010 08:26 AM
