Throw over saddle bags
Old Apr 9, 2007 | 11:26 PM
seikan1's Avatar
seikan1
Default Throw over saddle bags
Alright....I did it....I bought a cheap pair of saddle bags for my little scoot. How is the best way to secure them? Do you have a pic of your scoot with bags? I gotta have some ideas so that it won't be too unsafe or tear my bike up.
Old Apr 9, 2007 | 11:54 PM
PigInaBlanket's Avatar
PigInaBlanket
Default RE: Throw over saddle bags
I took off my seat,I laid thethe leather yoke part inbetween the bags over the fender, bolted the seat back on then tied the bags to the shock top and the rear turn signal.
Old Apr 10, 2007 | 12:28 AM
user 37474839's Avatar
user 37474839
I'd like to have some throwevers also..because I have a solo seat I've though about purchasing a Mustang Fender Bib to keep them from rubbing the rear fender paint.
Old Apr 10, 2007 | 01:25 AM
whaap's Avatar
whaap
The wear on the painted fender would be the one thing that would cause me heartburn. Take care of that and they can be kool.
Old Apr 10, 2007 | 05:32 AM
Oldtimer of NM's Avatar
Oldtimer of NM
The 1200 4 speed the OL used to have had bag supports, heavy wire loops that bolt to the fender. Throwover bags usually have straps or rawhide strings to tie them to the bag supports.
Old Apr 10, 2007 | 06:01 AM
bigtop1's Avatar
bigtop1
The concern for rubbing on the fender is real. I have gone to the corrigated rubber shelf liners used for tool boxes that cushion and keep parts from sliding. Cut a piece where the bags will rest on the fender and you should be good to go.
Old Apr 10, 2007 | 09:23 AM
capttawes's Avatar
capttawes
I'm like bigtop1 and use the shelf liner stuff under mine. My tourmaster slants have straps with quick release buckles that I just loop around the frame behind the batt./oil tank covers then around the signal mounts and they work out fine resting against the shocks (they also have a padded neoprene backing).
Old Apr 10, 2007 | 09:45 AM
bdavis's Avatar
bdavis
You can also use a thin mouse pad on the fender.
Barry
Old Apr 10, 2007 | 11:01 AM
mpaquette's Avatar
mpaquette
You can sort of see how I have them tied to the rear signals in one of my profile pics. I only secure the rear of the bag and it has worked so far. This year I am going to put a piece of felt between the fender and the yoke to keep it from rubbing the paint off.
Old Apr 10, 2007 | 11:47 AM
Hagar the Horrible's Avatar
Hagar the Horrible
Someone on Ebay sells standoff for the 04 and newer that only bolt to the shock so in a couple minutes you could zip them on or off. Protection hen you need it. Remove when you know you wont be using the bags for a while. Third choice, realize how important those bags have become and eventually break down and buy HD bags and just leave them on.
