Sportster S Sportster S Only
New Handle Bars
Old Dec 16, 2023 | 09:25 AM
float_6969's Avatar
float_6969
Hair spray isn't going to fix the issue. These aren't like normal motorcycle grips. The c-clamp on the inside of the grip and the nut on the end of the bar are what hold the grip in place. If the grip is loose, you to mess with those two things until it's tight.
I changed my stock grips out for the "wild ones" grips from Harley. The clutch side was loose for me as well. But I figured out that between the inside bar-clamp and the bar-end mirror adapter, I could get it tight.
To everyone saying that hair spray will help, look at how the stock grips works. Hair spray isn't going to help anything because the grip isn't attached to the handlebar that way.
Old Dec 18, 2023 | 08:28 PM
Bafsta's Avatar
Bafsta
you are totally right , the right grip already fit into place but i found the torq screw nut on the left handle to tighten up . all fits great now !
thanks for the help !
Fatbob1939
Sep 5, 2022 08:08 AM
cfiegehen
Jul 1, 2022 07:57 PM
goose222
Touring Parts
Feb 28, 2015 06:20 AM
Mrbien2080
Jan 17, 2011 02:36 PM
SDVmnt
Jul 27, 2010 06:59 AM
