The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
Darkside here I come
Old Jul 3, 2021 | 05:46 PM
Hoginedgewood's Avatar
Hoginedgewood
Default Darkside here I come
I'm totally disappointed with the factory tires on the 19 road king, just turned 10k and under 3/32" on BOTH tires.
so yes im impressed with the motor and abs, but I don't think I'm that abusive, usually ride 2 up and pull a small utility trailer couple times a year.
so if I darkside the back can I expect 15k ?
What do i do with the front?
can't mix radial and nonradial, are radials prefered?
Old Jul 4, 2021 | 06:52 AM
smitty901's Avatar
smitty901
There are no car tires that will fit the front, May work if you do a wide front end but that will cost you $3,000 or more. If you only got 10,000 out of a rear 180 you have other issues. You shout be getting 20,000 and others as much as 22,000.
If you go car tire in the rear you will be mixing B and R that is how it goes.
Front tire should last a lo longer than the rear.
You should have 16 inch rear. A 195/60R16 will fit prefect and be the same height as the factory 180/65b16 and 3/5ths of an inch wider.. Some run the 205/55r16 but it is not the same height as the factory tire.
Be warned this is a personal choice. It has it's up and down sides. I have done it That does not mean others should. Do your home work. Make an educated choice as with all mods and things outside the box.
Old Jul 4, 2021 | 06:55 AM
Notgrownup's Avatar
Notgrownup
You won’t find much difference with mixing bias and radial on a bike like this.
Old Jul 4, 2021 | 06:57 AM
Rogue1's Avatar
Rogue1
What size factory tire and wheel do you have now?
20000 miles out of a rear tire? Wow. I guess I don't talk to the right people and drive like a maniac
Old Jul 4, 2021 | 07:42 AM
PFWiz's Avatar
PFWiz
I don't personally know anyone who got 20,000 out of a motorcycle rear tire. When I used to run them I would only get 12 to 15K out of them and ended up having them changed out every other winter pre-emptively just so I did have to take the time during riding season.
Old Jul 4, 2021 | 08:44 AM
smitty901's Avatar
smitty901
double post
Old Jul 4, 2021 | 08:46 AM
smitty901's Avatar
smitty901
On the new frame , I have never gotten less than 20,000 on rear. Except with sidecar on but that is a different world.
Old Jul 8, 2021 | 04:56 PM
Hoginedgewood
Dunlop sport 5000 arrived today. 35 psi, I can tell a difference, it seems to roll left to right with the road crown change, corners felt fine. 195/60r16.
fits with a trailer hitch.
Old Jul 9, 2021 | 06:21 AM
PFWiz's Avatar
PFWiz
Try adjusting the air pressure up or down in 2 psi increments to find your sweet spot. Usually somewhere between 42 and 30 psi.
Old Jul 9, 2021 | 07:22 AM
Hoginedgewood
I’m anxious to do that tinkering around with the pressure but I started a thread about the valve core not being able to update.
franmel0416
Sep 16, 2019 10:15 AM
PPBART
Nov 13, 2017 09:39 AM
guesscrazy
Sep 6, 2017 09:39 AM
Johnnyiroc
Mar 26, 2010 04:06 AM
Jazz56
Apr 9, 2007 11:23 PM
