The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Stick with lambda. AFR is just confusing since none of us are dealing with fuel that has a stoich of 14.68. Unless that software is dealing with just a conversion. IDK?
That makes infinite sense given that is what the O2 sensor measures and the different rules that seem to be available.
I started with the FP3 and it's table for the same strategy was in AFR not Lambda ...as you say, rather confusing
I tend to think in AFR but I am old. When working at Lambda, I keep grabbing a calculator....
Go figure. Most non tuners on the internet tend to think in AFR. The programmers tend to think in Grams/Sec and true AFR. It is all the same when you tune to percentage error as the units all cancel out.
No, we can agree that something isn't right, could be the tune, intake leak, exhaust leak, bad injector etc. That's why you need more than just a scatter plot
Post up a big log, let's have a look
Sure, you can also have a hole in a piston. There is lots of things the tuning will never fix. Having a reality check is always good.
Andy
That's my point, you asked if "we can agree that the 'tune is less than quality'". The answer is NO, not by just looking a the scatter plot. The plot just shows there is an issue.
