Other Devices: Question for FP3 owners
I was not in Autotune mode over the weekend and Im sure that the fuel mileage would suffer if I was. It says right in the FAQ that while in Autotune mode that the bike will not run all that great. It uses some settings that help the FP3 learn correct values.
Ride with the new recommended flash un-altered for two tanks full of fuel. If you feel there is a need, do the Autotune. The Autotune processis also is not described well in any document. Here are the techs recs:
After starting an autotune, ride for an hour before applying the learned values. The bike will perform often times less well duiring this process as the settings are being tested. After an hour of riding, turn off the engine and apply, but do not finish the flash. Apply the learned values after each hour as the device can only change 15% of the values at a time. This process should be done at least 3 one hour segments or ideally 1 or 2 full tanks before "Finishing" the flash. The FP3 will guide you thru the process of turning on and off the bike. Very important- ride a large variety of riding types with both agressive and regular riding styles including low speed riding during the Autotune process.
After the finishing the tune, ride a full tank. You will not appeciate the full benefits until this time. My experince was fantastic. My CVO has never run as smooth, as cool, essentially without any popping, or pulled as strongly. It was nothing short of amazing what the device did. This was in comparrison to the Screamin Eagle tuner flash that the dealer did. The best part of the FP3 is that all flashes, including the bikes current flash are stored, and the bike can easily be reflashed back to any previous flash.
After being briefed at length by V & H on how to perform the Autotune my results were exactly what I had hoped for. However, I have not evaluated my mileage after the tune, but that was never my goal. That being said the FP3 does have a economy monitoring mode. Finally one of the best features is the ability to monitor an very large array of engine parameters such as intake and engine temps, torque, hp, and TPS info.
Ride safe.
DKCustomProducts.com
I will check into your product. I know DK is not far from me. in fact a friend of mine went to your office and picked up some rear lowering blocks for his 48 and I installed them for him. He is planning to come get some ignition coil and key relocation kits for him and I from DK also.
Decel popping can be heard on almost all aftermarket pipes. This is because they are open and when tuned for performance the AFR in the muffler body is just right for ignition of the unburned gasses.
The way that most folks try and get rid of decel pop is to over enrichen the AFR so that there is too much unburnt fuel in the muffler body to ignite. This is just a waste of fuel and does nothing to enhance performance.
btw, contrary to popular myth, decel pop is not generally a sign of a poorly tuned bike, rather, with open exhaust, if there is no decel pop, it is almost always a sign of a poorly tuned bike. Decel pop is almost always present with a properly tuned engine.
However, some folks do not like the sound of decel pop. There are two ways to get rid of it.
1. richen or lean the fuel, ONLY in a throttle off position.
2. Install some Thunder Torque Inserts which greatly reduce reversion, resulting in a change of AFR in the muffler bodies, and a reduction of decel pop as a result. BUT, the more important result of TTI's is that the reduction of reversion will Increase low and mid range torque, as well as MPG.
Come on down and visit us anytime! Might want to call ahead and make sure we have what you are wanting to pick up. Our shipping facility is in Memphis, our manufacturing & Customer Service is down in Red Banks, MS.
Then continue to auto tune in the same slot you were in before?
