The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Other Devices: Question for FP3 owners
Old Jul 24, 2016 | 05:15 PM
Nitro 54's Avatar
Nitro 54
What will adding one firecracker in the FP3 for popping do to fuel mileage if any? Anyone try this option yet?
Old Jul 24, 2016 | 05:19 PM
RFG7680's Avatar
RFG7680
I ran the auto tune. Gas mileage seems about the same. 200 to 210 a tank and takes 5 gallons to fill it. Sometimes a bit more. Sometimes less depends on how I rode. But it certainly did not kill my mileage.
It did make my bike run 100% better.
Old Jul 24, 2016 | 05:21 PM
splattttttt's Avatar
splattttttt
From what I understand, popping, or decel pop is a condition produced by too lean a fuel ratio. Richening it wil reduce it partially or all. But efficiency will frop some while power will increase
Old Jul 25, 2016 | 05:13 AM
Gordon61's Avatar
Gordon61
Originally Posted by checkers
Yes a flash tune requires riding and turning the key off and back on through several cycles. Make it a process to stop and shut the bike off and restart and go again.
That's a new one ...where do you get that from ??
Old Jul 25, 2016 | 05:36 AM
Gordon61's Avatar
Gordon61
The on and off a few times I presume you are referring to basically running a number of autotune sessions (same strategy as with any flash tuner)
The FP3 allows you to "Apply" what you have learnt so far, reset all of the hits screen (because you are now using that data) but keep going with another autotune session (if you want to do that).
The "Finish" option applies the learnt values and exits autotune mode.
Of course, you can stop and start your bike anytime you like and the FP3 will just continue whatever it was doing when you switched it off when you start the bike again.
What DOCGSS said
Old Jul 25, 2016 | 06:07 AM
splattttttt
Gordon, it was obvious to me what he meant. Was probably in a hurry when typing.
But thanks formyour input on a more detailed evaluation.
Old Jul 25, 2016 | 06:35 AM
Gordon61's Avatar
Gordon61
Yea, no worries we knew, it was just for the OP's benefit, sounded like he was new to flash tuners.
Old Jul 25, 2016 | 08:43 PM
checkers's Avatar
checkers
When using any flash tuner, the key cycles are part of the ECM adaptive strategy learning process. When reprograming the ECM does still have to "learn" And part of that process is done through key off/key on cycles For example " I have done my flash and the bike ran terrible for awhile." Or "run a few tank fills and then apply" This is a basic description. I also suggest, that when you turn the ignition switch to the on position, wait 3-5 seconds before cranking engine over. This will assist in the "learning" process.
Old Jul 26, 2016 | 03:38 AM
Gordon61's Avatar
Gordon61
mmm, so not just flashing the map and switching off n back on ...interesting thought, and maybe Steve could comment on that as well.
Funny but I was looking at the FP3 again and they do go on about running a tank through and do this and run another tank through etc ...I wondered if somehow their tuning was using the adaptive values.
The power vision on the other hand switches adaptive off during the tuning process (or at least I thought it did??). You get your VE's centred properly, then it switch adaptive back on once you are finished.
Which tuners were you thinking about here, just I've never read anything about adaptive and key off sequences ...other than the alarm system and disabling EITMS ??
EDIT: Just checked and PV defo switched Adaptive off while auto tuning VEs ??
Old Jul 26, 2016 | 03:45 AM
Gordon61's Avatar
Gordon61
Was that advice not to ensure that the fuel pressure (a very important variable in the EFI equations) was up to where it should be?? Long time since I've read it but was that not in the owners manual?
