The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Throttle Blip Test
Old Dec 14, 2016 | 07:38 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by 09fxdfse
Did you wonder why the RPM is increasing before the TP ?
It's not.. I think you are confusing TPS and MAP..
I personally don't understand what is going on.. The pic with the flat topped map, has a greater increase in RPM than pointy one.. One thing to note is that the throttle blip event is really only one sample wide in the pointy pic and the pic with the flattop is 2 samples wide.. I've identified sample rate and RPM..
I really don't see any significance other than the throttle seemed to be held open longer in the flat topped pic and the RPM is a little higher..
Old Dec 14, 2016 | 07:49 AM
Max Headflow
Here is the other graph..
Old Dec 14, 2016 | 12:15 PM
Gordon61's Avatar
Gordon61
I think he meant my MLV picture from a PV log ...which does indeed look rather strange in that regard
Old Dec 14, 2016 | 03:02 PM
hrdtail78's Avatar
hrdtail78
Is there any changing to the transit fuel tables for any of this?
Old Dec 14, 2016 | 03:07 PM
Max Headflow
If it's a PV thing then talk to Steve Cole about it.. You'll get a nice lecture on data monitoring packets..
Old Dec 14, 2016 | 04:52 PM
Gordon61's Avatar
Gordon61
Indeed I thought that was a really useful thread Steve did, should have been a sticky ...just a thought. It was a very good insight into the sensors and such.
Old Dec 14, 2016 | 05:02 PM
Gordon61's Avatar
Gordon61
My example? No, I've not altered the AE or DE tables from the DJ supplied map, which are the same as my stock map backup.
Don't sweat it on my account, I know you guys are busy. I'm still playing/learning and was just looking to what I might learn extra from Wiz's blip test. I'm not getting any noticeable hesitation and no pops or farts on the overrun so hadn't looked at the AE/DE yet
TTS says to use the IVO value on the upturn of the graph, or possibly the setting just before that. I just thought it was interesting that my crap attempt at a blip test may support that advice ...but this is only one bike, and one cam so others experience may obviously differ.
Lambda
24
May 22, 2021 09:18 AM
ezryder62881
Nov 2, 2016 08:09 PM
cspcrx
Oct 30, 2014 09:47 AM
triked
11
Apr 14, 2010 03:33 PM
flushguy
Apr 16, 2009 06:49 PM
