The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Engine Temp's
Old Nov 22, 2016 | 01:00 AM
Sparra's Avatar
Sparra
Default Engine Temp's
Just wondering if when you are set up for Vtuning with TTS do your engine temp's run a little hotter while you are doing runs and when you set everything back to original do your temp's drop a few degrees...My temp's while tuning are around 250 farenhiet...Is this about normal..
SE255 cams,Bassani Road Rage,Air...otherwise stock 2010 96ci WideGlide.
Cheers...Sparra
Old Nov 22, 2016 | 06:01 AM
Oz Nightrain's Avatar
Oz Nightrain
I don't have the TTS but I'm sure your vtune would be similar to my smart tune. Everything gets set to 14.6 so your O2 sensors can collect data, so yeah it will run a little hotter but as long as you don't ride around all day like that revving the nuts off it you should be fine.
'06 NT, 95", S&S .510g, V&H BR 2-2, K&N AC, P&P Heads, SEPST.
Old Nov 22, 2016 | 09:57 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Some notice a slight increase while tuning so that is not uncommon. 250 F is well in the normal heat range for a Twin Cam engine. They typically will run from ~ 210 - 290 F in normal operation.
Old Nov 22, 2016 | 01:20 PM
Sparra's Avatar
Sparra
Thanks for the reply's fella's...
Cheers...Sparra
hscic
Apr 27, 2017 01:59 PM
Porgey
2014-2024 Touring Models
Sep 10, 2015 06:16 AM
hog120
Jul 8, 2014 12:54 AM
Fritzables
May 4, 2014 01:28 AM
fogcity123
EVO
Aug 26, 2010 03:25 AM
