The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: Why add fuel at 0% throttle position under 1k rpms?
Old Sep 16, 2017 | 12:15 PM
marcodarq's Avatar
marcodarq
to your original question,,,with a pc and the other flash tuners for that matter,,,,in the VE tables
PC3or 5 if you add value in the 0% throttle collum, at 1krpm or lower you are making the idle fuel mixture richer, if you take away value, you make it leaner. some bikes need this done to maintain a good idle quality and sometimes it helps with engine cooling. the richer mixture tend to run cooler than lean. it is not usually large adjustment, but i find it helps alot when the bike wants it.
m
Old Sep 16, 2017 | 06:09 PM
SgtThump's Avatar
SgtThump
m
Thanks for that info. Changing those to 0 helped my street glide idle more smoothly. Just changed those to 0 on my sportster today and didnt really notice a difference. Like anything, i guess it depends on the bike!
Method36
Jun 22, 2021 04:00 PM
grasmo
Jun 11, 2014 10:19 AM
uwiik
Oct 21, 2013 01:18 PM
nemick
Mar 11, 2009 08:15 PM
handyhoward
Exhaust System Topics
14
Aug 23, 2007 08:42 PM
