The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
No Device: VE VS Comp
Old Dec 25, 2017 | 08:16 PM
darreldanger's Avatar
darreldanger
Default VE VS Comp
If I increase compression how much if any will it affect my Volumetric efficiency?
Old Dec 26, 2017 | 01:21 AM
Sarhan's Avatar
Sarhan
No guessing over here you need to retune your VE
Old Dec 26, 2017 | 11:24 AM
FLTRI17's Avatar
FLTRI17
VE is affected anytime airflow is altered. By increasing compression the airflow changes so recalibration is necessary.
Bob
Old Dec 28, 2017 | 05:37 PM
darreldanger
Bob
Yes but I don't think airflow is affected by comp...
Old Dec 28, 2017 | 07:05 PM
FLTRI17's Avatar
FLTRI17
retracted
Old Dec 28, 2017 | 07:27 PM
jbarr1's Avatar
jbarr1
Listen to Bob. It most definitely affects airflow.
Old Dec 29, 2017 | 11:02 AM
hrdtail78's Avatar
hrdtail78
If it affects airflow or not isn't what would concern me. How compression affects the efficiency of the air fuel ratio is what would concern me. Adding compression can also affect things like squish, flame front travel, and atomization of the fuel. This can and will affect air fuel ratio. Besides, with added compression. Wouldn't one want to address the timing side of tuning as well for all the same reasons?
Tale of two 124's. Both have same cam, static compression, and lower output. One has shaved heads and flat tops. The other has 7 plus cc domes. Timing different between the two is 7-9 points. There is more to tuning than adding and subtracting fuel based on compression values alone.
Old Dec 29, 2017 | 04:58 PM
marcodarq's Avatar
marcodarq
adding compression definitely effects your VE. the whole point of adding compression is to improve VE...improve VE=better power&efficiency. if you add comp to any measurable level you will need to re-tune your VE tables in order to get the most benefit from it.
m
echo4tango
Exhaust System Topics
24
May 3, 2020 08:00 AM
WS6 Formula
Pacific
Apr 3, 2009 09:23 PM
JockWhisky
Mar 18, 2009 10:31 PM
DHOODENPYLE
Jun 15, 2007 11:03 PM
