The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
TTS: Iac help
Old Apr 11, 2021 | 12:34 PM
FREDStr33tbob's Avatar
FREDStr33tbob
Default Iac help
Ok so i had a tune and the bike ran perfect. I went from a 103 to a 107(due to a piston ring Failure) with more compression and bigger roller rockers and bigger injectors .
i learned a lot in tuning the last time with WIZ and setting the IAC
with the old tune the i set the IAC to the recommendation of the IAC analyzer and never looked back...
Here is where i am at so far,
the IAC cranking fuel was way to high so i cut it in half. It would cause really high idle off start then drop drastically,
No matter what i set the table to on the IAC warm up. The IAC valve it self continues to open steadily and cause the bike to hiccup and a small surge in idle.
long question short, why does the IAC continue to change value if i set it to what the table recommended?
im like 90% there. I just dont understand why it continues to rise with temp of the motor? What am i missing?
Old Apr 11, 2021 | 03:34 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Understand that what you are setting is starting place for the IAC at various conditions. Once the engine is running the ECM takes over and will adjust the IAC as needed to hold as close as it can to the desired Idle Speed that is set. So if your Idle Speed Table has it set to idle at 1000 RPM the ECM will do what's necessary to try and get that idle speed.
peci02@bellsouth.net
Apr 19, 2017 05:28 PM
HDsportster99
Jun 22, 2014 11:37 AM
jorswift
Jun 3, 2009 06:10 PM
gazzer
Jun 30, 2008 05:10 PM
bendel
Feb 26, 2006 02:19 AM
