"The Florida Crew" Rides and Information From The Florida Crew.
Guess the gastank?!?!
Old May 5, 2012 | 06:01 PM
Skrimshaw's Avatar
Skrimshaw
Default Guess the gastank?!?!
<img src="http://sphotos.xx.fbcdn.net/hphotos-ash2/39070_452497970378_504070378_6611249_7468791_n.jpg "><br><br>A friend of mine was asking what this tank is from. The only info we have, is that it came from a custom motorcycle shop and is HD. I don't know if any of that is true but I was hoping to use your knowledge to try and determine make. Thank guys.<br>
Old May 5, 2012 | 06:04 PM
Skrimshaw's Avatar
Skrimshaw
Sorry guys, trying to figure out how to get the picture up.
Old May 5, 2012 | 06:07 PM
Skrimshaw's Avatar
Skrimshaw
Old May 5, 2012 | 07:00 PM
jumpmasterjay's Avatar
jumpmasterjay
Are you 100% sure it was made by H-D? If so, I'd bet something from the 1930s-50s, but cut in 1/2 by a custom maker. I don't think H-D ever had twin tanks.
Old May 5, 2012 | 07:08 PM
perki48's Avatar
perki48
Holly crap you must be young, or just joking. Its a Fat Bob tank off of a harley, probably FLH. Can't tell for sure by the pic but probably a 3 1/2 Gal set. I gaurantee its stock Harley.
Old May 5, 2012 | 07:15 PM
Stiggy's Avatar
Stiggy
Harleys FLH's have had split tanks since 1936 to around 1984. Softail til 1999 ( or so.)
Gawd, now I feel old!
Old May 5, 2012 | 09:58 PM
Skrimshaw's Avatar
Skrimshaw
So, we can safely assume it is HD. But would you guys have any clue how to figure out a year?
And I appreciate the help!
Old May 5, 2012 | 10:35 PM
j1mmy's Avatar
j1mmy
you folks are making me feel old.. that is a shovelhead flh fuel tank.the early tanks had mounts for a shifter, and a rod through for the fuel valve and were 3.5 gallon,later pans still used the weird valve, and were 3.5 gallon..shovel didnt have any of the other stuff,just a current fuel valve on the bottom, and were 5 gallon.the 3.5 tanks, the side drops rite off next to the filler, the 5 gallon tanks are more bubble shaped. all twins and flatheads had split tanks till about 80. after the fatbob tank, evo's used flat side split tanks, still pretty similar looking, but mounted different and rubber mounted
Old May 6, 2012 | 08:26 PM
jumpmasterjay
Split tanks...all they way until 1999...true, dual tanks...with only a cross over at the bottom?
Old May 6, 2012 | 09:18 PM
perki48's Avatar
perki48
Yep, only a crossover hose up till 99' on some models........Softails.
