The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Oil Problems?
Old Mar 22, 2009 | 08:37 PM
pawl0001's Avatar
pawl0001
Stage II
Default Oil Problems?
The oil in my 02 1200c has vanished from the tank but did not leek on the ground, so i was wondering where it might have gone
thanks
Old Mar 23, 2009 | 12:53 PM
jmeyer58's Avatar
jmeyer58
How long since you last checked it?
Who did the last service?
Any recent motor work?
Any blue smoke?
Old Mar 23, 2009 | 01:00 PM
kromdom's Avatar
kromdom
you posted in the RIGHT place already: https://www.hdforums.com/forum/oil-a...-problems.html
Old Mar 23, 2009 | 01:05 PM
ranger56528's Avatar
ranger56528
Its in the crank case.......
Old Mar 23, 2009 | 01:59 PM
Serg06's Avatar
Serg06
I agree with ranger. my chopper used to do that. I fire it up and give it a minute and it would go back to the tank.
Old Mar 23, 2009 | 04:33 PM
Da Gumpmeister's Avatar
Da Gumpmeister
It 'wet sumped' itself. The oil seeped by the check ball, and it, like Ranger said, ended up in your crankcase.
DO NOT be alarmed, if when you start it, it pukes oil out of your breather.
BUT if it ALL drained down, EVEN over the winter, best lap that seat and put a new ball check in. NOTE: it will NOT hurt anything IF you don't. But your oil will do it again, when it sits for peroids, til you fix the check ball and seat. IF you ride a lot in the summer, in all honesty, I wouldn't worry 'bout it til next winter's maintenance. JMFUO, tho.
Your results may vary, some assembly required, batteries not included.
Old Mar 23, 2009 | 07:09 PM
JW1200's Avatar
JW1200
Sounds like it's actually the check ball, and it's located in the oil filter mount.
The oil filter mount houses the oil filter, check ball and spring, and oil pressure
switch. If you remove the oil filter adapter, (the part you screw the oil filter on), you can access the check ball and spring.
8541hog
Jun 28, 2022 04:42 PM
drd21968
Custom Models
Sep 4, 2018 05:44 AM
ffracer297
Engine Mechanical Topics
Apr 21, 2014 07:40 PM
madman13
Oil Archive (no new posts)
Oct 2, 2012 08:57 AM
WARG
Oct 16, 2007 10:39 AM
