The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Help with removing pitting
Old Jan 4, 2013 | 11:41 AM
Jake17HD's Avatar
Jake17HD
Can anyone help me with the name of the part? I am just going to replace it but I am having a helluva time finding it.
Old Jan 4, 2013 | 12:37 PM
glide2meetu's Avatar
glide2meetu
It appears to be the fender support
59950-89 for the left one and
59951-89 for the right one.
Item 28 HERE
Old Jan 4, 2013 | 01:19 PM
Jake17HD's Avatar
Jake17HD
You my friend, are awesome. Thanks!
Old Jan 4, 2013 | 09:26 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
I haven't got the patients for that. If it bothered me I'd put the 40 grit sanding disk on the angle grinder and polish it up.
Old Jan 5, 2013 | 04:08 PM
Ragtop's Avatar
Ragtop
Originally Posted by uncle larry
yep ... What you're seeing is "patches" where the factory clear coat has been worn through ... The best way to fix it is to take off the affected part ( strut ) and use a stripper or "easy off oven cleaner" to remove the clear coat ... Then starting with a 600 grit wet or dry sandpaper ( using water also ) sand out the entire surface ... Then use 800 grit, then 1200 grit ... Followed by a polishing with something like simichrome http://www.simichrome-polish.com/ or mothers aluminum polish http://www.mothers.com/02_products/05100-05101.html and polish to a "brilliant" shine ... Then if you want you can apply a clear coat over the part or leave it uncoated keeping in mind that you will need to "touch it up" once in a while
^^^this is the correct answer^^^^
vtncus
Apr 13, 2010 02:31 PM
forever young
Feb 21, 2008 01:20 PM
UNYboater
Feb 9, 2008 02:22 PM
Deuced512
General Topics/Tech Tips
Jun 30, 2007 10:41 AM
