Need a Power Vision Map for 117"
Old Sep 21, 2014 | 02:12 PM
$tonecold's Avatar
$tonecold
Default Need a Power Vision Map for 117"
I have purchased a 117" motor for which I will need a Power Vision map. It has 10:1 compression, 2" intakes, 1.65" exhaust, Drago's 580 cams - intake 20 / 42 .578 lift 243 duration @ .050; exhaust 44 / 18 .568 lift 243 duration @ .050. I plan to run the stock 50mm TB with stock 4.3 injectors for now, it does come with a SE TB. I will run a Drago's 2:1 exhaust with the 2.55 collector. If there is more information needed let me know and I will provide it if I can. I would like a map that is close enough that auto-tune can bring it in and make it right.
Old Sep 21, 2014 | 02:38 PM
firefighter156's Avatar
firefighter156
Fuel Moto can help you with a Map. You may want to reconsider the 50mm TB on a 117". Just sayin..
Old Sep 21, 2014 | 11:15 PM
$tonecold's Avatar
$tonecold
I am going to ask FM if they have a map that will work, I just thought maybe someone would have a build close to this that had a good map. I will consider using the SE TB, but I am looking for a lot of torque down low, so the smaller TB might just be the ticket.
Old Sep 22, 2014 | 07:47 AM
firefighter156
Do some checking around. A 117" with head work like you did I'm thinking most will tell you to do a 58mm SE and a high flow air cleaner. Just my .02 but you have a lot invested don't leave anything lay on the table at this point. Your down low TQ is going to be decided much more by your cam choice then the TB.
Old Sep 22, 2014 | 01:01 PM
$tonecold's Avatar
$tonecold
I will check on this before making a final decision. I'll have both, so it won't be a problem to install the one that will work the best.
Old Sep 22, 2014 | 05:37 PM
firefighter156
evhid1
The Dyno Room
Jun 19, 2017 05:57 PM
iDodgimus
May 21, 2014 04:19 PM
02Ultra Bagger
Apr 9, 2014 08:10 PM
CndUltra95
Aug 8, 2007 08:35 PM
maineultraclassic
Nov 26, 2006 08:15 PM
