stock street glide tri bar light, is there a bulb?
Old Sep 22, 2014 | 08:59 AM
Jersey Drew's Avatar
Jersey Drew
Default stock street glide tri bar light, is there a bulb?
the one i have don't seem to be working. is there a bulb that is replaceable or does the entire unit have to be replaced?
Old Sep 22, 2014 | 09:43 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
No bulb. It is a sealed unit they do sell replacement units that act as a brake light too. Check the wire connection first. Go up on the left side of the fender till you find where it connects. Was it working? Then just stopped?
http://www.harley-davidson.com/store...-light-upgrade
Old Sep 22, 2014 | 09:53 AM
Jersey Drew
the bike was purchased and the light was not working. i will inspect the connection point and see if there is any corrosion. if not i will test it and if i see power i will assume the light is dead and just do the upgrade to led.
thanks for your help!
Old Sep 22, 2014 | 10:45 AM
Sweet Lew's Avatar
Sweet Lew
5th Gear
It's a sealed unit. Pry it open, go to the local auto parts store and buy a strip of red LEDs and seal it back up.
Old Sep 23, 2014 | 04:38 AM
Rustrtal's Avatar
Rustrtal
Custom Dynamics is now selling an LED replacement unit too.
Old Sep 23, 2014 | 05:10 AM
JY Kelly's Avatar
JY Kelly
I got the module to make it a run/brake light. Do yourself a favor and make that change.
Old Sep 23, 2014 | 09:34 AM
frankegd's Avatar
frankegd
I got one taken apart, it's a 4 LED strip. I can seal it back up if you want to buy it. It came off of a '14 SGS.
Thank you
FrankEGD
Old Apr 12, 2020 | 08:58 PM
PCRRVP's Avatar
PCRRVP
1st Gear
I have a 2012 street glide, my tri bar light was not working, I unplugged it, removed the unit and noticed that there was NO led in it, is that normal??
Old Apr 13, 2020 | 12:26 AM
Dynamick's Avatar
Dynamick
Yes it is, for a Canadian model. I'm going to install a Custom Dynamics LED replacement to make it functional.
Old Apr 13, 2020 | 05:13 AM
Hephaestus's Avatar
Hephaestus
+1 on this. I also got the custom dynamics run/brake module for the tri bar as well and glad I did!
