Serious Audio System Help
Old Sep 25, 2014 | 09:23 PM
Kokes58's Avatar
Kokes58
Default Serious Audio System Help
I have a 2009 Ultra Classic and recently purchased a CVO Sound System from the Touring Sales Forum (https://www.hdforums.com/forum/touri...eet-glide.html). In doing my detailed research on how to install the amp I found the system is basically the Boom Audio Custom Touring System (P/N 76000209). Tonight I came across this chart (http://www.harley-davidson.com/en_US...dio_matrix.pdf) and on the second page it shows the system will not work with a FLHTCU? I'm partly confused on how it will work with a FLHTCU but not a FLHTCU. Does this sound right or does anyone know how I can install the amp? I thought the price was decent for the system but if I can't install it, then it was a complete waste of money. I'm open to any suggestions on how to use this system.
Thanks
Old Sep 25, 2014 | 09:39 PM
hd_rolling's Avatar
hd_rolling
I thought all the CVO stuff was 1 ohm and your bike is 2 ohm? Might want to ask in the audio section, great info from that area.
Old Oct 30, 2014 | 12:28 PM
UltraNutZ's Avatar
UltraNutZ
Thanks
you will need to either manufacture your own wiring harnesses for this setup or get the CVO wiring harnesses. Either way, this is WAY too much work for the little gain you're going to get out of the CVO setup you purchased. You have much better options and a lot less headache available to you sir.
Old Oct 30, 2014 | 02:33 PM
0ldhippie's Avatar
0ldhippie
Beat me to it...
Armoli
Audio Systems
Jun 9, 2018 07:08 PM
Badger541
Audio Systems
Apr 19, 2017 09:23 PM
usadefender1977
Audio Systems
Feb 23, 2015 09:41 AM
ramair1
Feb 10, 2012 10:17 AM
mntanakd
Audio Systems
May 8, 2011 03:24 PM
