Apes on CVO Ultra?????
Old Sep 27, 2014 | 05:53 PM
powerman1972's Avatar
powerman1972
Originally Posted by fireman9170
I wanted to get some 14 inch apes on my 13 CVO ultra, so I went to local dealer today to get a price. Turns out they say that it can be done, but 95% of all bars do not accommodate the OEM heated grips that came on my bike. I do not want to do away with them, they’re very useful. So, anyone here put apes on their CVO ultra??? They told me 9 hrs minimum if I find bars that will work. Thats around $800 labor minimum. Not sure I want them that bad.
I just had the dealership install 14" Wild1 chubbies on my standard 13 Ultra Limited. Total labor was 11hrs. That was for installing bars, wire extensions, and extended braided clutch and brake lines and ABS bleed. The Wild1's let you retain the heated grips. If you go with the 14" you will need +8" on both the clutch cable and brake line. Hope this helps.
Old Sep 27, 2014 | 05:56 PM
powerman1972
Heres a picture!
Old Sep 27, 2014 | 06:01 PM
fireman9170's Avatar
fireman9170
what was total cost for wires , lines , bars and everything?
Old Sep 27, 2014 | 09:00 PM
baldguy13's Avatar
baldguy13
I have 14" Vindiktas on my 14 SGS with Harley Heated grips. Works great.
Old Sep 27, 2014 | 09:07 PM
fireman9170
not sure I can spend $1200-$1300 for apes. Seems outrageous. I would’ve never guessed it would be that much
Old Sep 27, 2014 | 09:52 PM
Bgill's Avatar
Bgill
Call Joe at Vindikta and he can set you up, I have a 2013 FLHTCUSE8 with a set of his 16"s meat hook style bars and he made them up to take heated grips at no extra charge.
A bar change is going to cost you ~900.00 to complete with all parts 7 labor included if you shop smart and farm out the labor which should be billed at 5 - 6 hours tops if they know what they are doing. As a data point ask your "stealer" what's the flat rate time to change a set of bars by the book or under an insurance claim. Its less then half what I estimated above being fair 9the wiirng can be a PITA.
If they can't do it for 5-6 hours or less they are either incompetent or opportunist and either way you don't want them touching your bike, shop around and don't be afraid to check with an Indy or two for quote.
Also the Vindikta bars are 1.5" diameter which make the wiring a whole lot easier and quicker...
Good luck.
Old Sep 27, 2014 | 10:54 PM
powerman1972
then you don't even want to know what I spent on my setup! I added chrome accented heated grips versus the stock black ones, chrome levers, chrome switch covers, etc! It was a lot of $$ but worth the comfort and you only live once! I spent enough money that the dealer offered to store my bike and the wife's bike in their heated facility for nothing over the winter!
Old Sep 27, 2014 | 11:21 PM
mike5511's Avatar
mike5511
I'll do mine myself. I don't care if it takes all winter. Why? Some guys enjoy cleaning and polishing and find it therapeutic, I like doing the mechanical stuff, even though my abilities and experience are limited. With the manual and all the videos available to help, there is a whole bunch of stuff the average "shadetree" can successfully accomplish.
I'll put your bars on if you'll detail my bike!!! Now that's a good deal IMHO!
Old Sep 28, 2014 | 01:45 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
I went with the W.O.'s 577's (12.5 inch rise I believe).
I had no choice as it was impossible for me to ride using the OEM handlebars.
All the wiring, as well as the clutch and brake lines had to be lengthened.
As I recall, the dealer had a hard time locating one of the fittings for the hydraulic lines but everything else went well and I thoroughly happy with the bars.
Old Sep 28, 2014 | 07:19 AM
fireman9170
your right, don’t even want to know. I just dropped $2300 on it for some other stuff. I gotta slow down
