12 volt power under the fairing?
Old Sep 28, 2014 | 07:19 PM
cdestuck's Avatar
cdestuck
Default 12 volt power under the fairing?
Picking up a 2014 SE Limited this week and want to get to work on some work on it. Need to open up the fairing to hard wire in the GPS and phone charging. I was wondering if there was any type of 12 volt plug under there that I can use to pick up some switched power.
On my 2010 I just spliced into the wires going to the lighter. I like to not do that this time as the wires going to the lighter are pretty small gauge. Anyone know if there is a good power source there? Thanks
Old Sep 28, 2014 | 07:29 PM
grizztracks's Avatar
grizztracks
I found a 12 volt 2 wire connector under the fairing high on the right side on my 14 SG. I don't remember wire colors but it was a keyed power source.
Old Sep 28, 2014 | 07:31 PM
cdestuck's Avatar
cdestuck
Was this a plastic formed unused plug?
Old Sep 28, 2014 | 07:44 PM
GlidingJoe's Avatar
GlidingJoe
Yes it is an unused plug.. Used for Hidden antenna and such.. there a few switched power ports/plugs under the fairing put that is right from the P&A fuse..
Old Sep 28, 2014 | 08:55 PM
Geezer glider's Avatar
Geezer glider
Don't they still have the spare power source at the headlights?
Old Sep 28, 2014 | 11:22 PM
Casper's Avatar
Casper
I have a 14 Tri Glide with the info center. On the right side of radio screens a flip up cover that has a USB port for charging and connecting any phone or mp 3 player, shouldn't you have the same? Haven't been inside fairing yet but I always used the two wires in the headlight loom near the headlight plug, red and black wires capped off with a red plastic cover.
Old Sep 29, 2014 | 01:16 AM
cdestuck's Avatar
cdestuck
Casper, I like to hard wire in both the phone and gps. Guess there is a couple options in there better than what I've used before. Tks Guys
pdave
Audio Systems
Oct 28, 2018 11:27 AM
dontdropit
2014-2024 Touring Models
May 12, 2014 10:10 AM
dontdropit
May 11, 2014 04:28 PM
slapshot12
Audio Systems
Nov 14, 2013 04:38 AM
creep1
Aug 14, 2008 05:52 PM
