push button alarm bypass?
Old Oct 13, 2014 | 10:37 AM
EasTexUltra12's Avatar
EasTexUltra12
Originally Posted by mkguitar
see if you can unplug the siren module until you are done experimenting.
mike
This didn't work on my 12 UC. Admittedly, it might work for the OP's 06, but it definitely didn't work on my Ultra. As soon as you pull the siren out, it loses power and goes off for as long as the internal battery will last. In my case, that was a long time. Don't ask me how I know.
David
Old Oct 13, 2014 | 10:57 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
David
This is for the newer proximity FOBS like yours, to disconnect the siren.
If you have a working FOB.... with the FOB present, turn the ignition on and wait for the disarm of the security system. Pull the maxi fuse. Then you can disconnect the siren.
Old Oct 13, 2014 | 11:38 AM
skratch's Avatar
skratch
Originally Posted by shooter5074
You have to push the button to activate or disarm the system with the older manual FOB.
yeah, i knew that..... but forgot.
Old Oct 14, 2014 | 09:54 AM
Jersey Drew's Avatar
Jersey Drew
Here's the way to do it with the manually activated system
Turn the ign switch to accessory,
QUICKLY hold down both left and Right signal switches until the key
lamp flashes rapidly, enter the
first digit on the left And use the right as an 'enter' key,
enter all five digits of the
passcode and the system will Disarm, if you screw up, the
alarm will activate and you will have
to wait ten minutes.
So as an example, if your code was 12345..................
Ignition to accessory.
Quickly press and hold both signal buttons until the key lamp flashes.
In order:
left 1 then press right
left 2 then press right
left 3 then press right
left 4 then press right
left 5 then press right
System should disarm
i will try again. but the last time i did get the fast flashing but i did not see the 0---- you are supposed to see on the odometer. i got that far but could not enter the code.
Old Oct 14, 2014 | 10:07 AM
shooter5074
I'm not sure of the 0 that you're talking about. I thought it would show 5 dashes.... just enter the code when you get the rapid flash. After you enter the code, if you did it right, you will get the disarm turn signal flash.
Smoking Gun 44
Jul 6, 2019 12:01 PM
amkaos
Apr 5, 2016 09:31 AM
ebartman
Jan 30, 2013 09:25 AM
greg3131
Apr 15, 2008 06:18 PM
rhiggins
General Topics/Tech Tips
Aug 6, 2007 10:59 PM
