Fob programming probs
Old Apr 5, 2016 | 09:31 AM
amkaos's Avatar
amkaos
Default Fob programming probs
=I did this over and over. I get confirmations at each step zept the very
last one.. The fobs aren't recognized or something..
New installed batteries show voltage ok from the contacts..
The push button switches show correct R.
Idk what's going on.. Web doesn't show any alternate sequence..
Thx
Turn your Ignition Swich in this order. ON-OFF-ON-OFF-ON!
3. Depress your LEFT Turn Signal Switch TWICE!
4. Depress your RIGHT Turn Signal Switch ONCE!
5. Then Press your Left Turn Signal Switch ONCE more.
6. Then hold the Key FOB up to your left handlebar controls until the turn signals flash TWICE. Hold the other one up after they flash.Thats if you have 2 Key FOBs.
7. Now turn off the bike and check it. Hold and Depress the FOB once. The Turn signals should flash ONCE! To dissarm. Double Click the FOB and the Turn Signals should flash TWICE!
EDIT fixed it.. After getting no where last nite and earlier this Am,, lil bit after posting,
It worked ok.. Of course
Scudda
Feb 9, 2020 10:53 PM
ebartman
Jan 30, 2013 09:25 AM
Reindeer
11
Sep 27, 2012 06:34 AM
rickoshea45
Sep 11, 2012 10:41 AM
Trikerjon
Apr 4, 2011 11:56 AM
