premium shocks
Old Oct 7, 2014 | 12:58 PM
geezerg's Avatar
geezerg
3rd Gear
I set mine at 7 clicks for solo, I weigh 170, and 12-13 clicks for 2 up. I would think at 0 they wouldn't be working much.
Old Oct 7, 2014 | 01:21 PM
rpking's Avatar
rpking
Thanks for the advise everyone
I'm glad to hear that they have potential to get better with more miles on them
I will keep riding and play with the adjustment some to see what works best.
I still have my eye on a certain fat lady at work, I'm not ruling out that option either!!!
Old Oct 7, 2014 | 01:33 PM
Hogpro's Avatar
Hogpro
Former Sponsor
The instructions for the 13" premium ride shocks I have said to set to 0 clicks if under 220 lbs. So that is where mine are set.
Old Oct 7, 2014 | 01:34 PM
Talldog's Avatar
Talldog
Originally Posted by rpking
I have a 2013 Street Glide
I put the Harley Davidson premium shocks on this past weekend
Do they soften up any after some miles of riding?
I have the adjustment **** counter clockwise the entire way, I can bounce up and down on the seat as hard as I can and it seems as though instead of shocks I have solid steel bars bolted on in their place.
I rode around 30 miles or so on Sunday, I felt every bump, some even sent me bouncing off the seat, these shocks aren't any better than the stock air shocks I took off.
From what I have read Progressive shocks even with the standard springs are stiff for some people also.
Does any shock company make shocks that will soak up the bumps for a guy that is 175lbs.
I ride solo 100% of the time.
Thought about getting a fat girl to ride with me, kinda hate to go to that extreme to get a comfy ride.
Anyone have the same problem, if so, have you found a solution yet?
Thanks
Not sure if it would make a difference in the stiffness, but just wanted to make sure you got the right shocks for your SG, 54000091 ? The other ones, 54000008 are a little higher.
Old Oct 7, 2014 | 01:51 PM
SafetyMan's Avatar
SafetyMan
Longer.
And softer.
More travel....
Old Oct 7, 2014 | 04:20 PM
Mr HOG's Avatar
Mr HOG
I put the premium low shocks on my 09 Street Glide like 3 years ago and noticed a big improvement over stock right away. Not sure what I have them set at but it's at least a few clicks off zero. I'm 200 lbs and my lady is around 100. The shocks are a little stiff when riding solo but perfect when she's on the back so I just leave them at the same setting all the time.
Old Oct 7, 2014 | 04:47 PM
FlaHeatWave's Avatar
FlaHeatWave
The Premium Shocks were a definite improvement ('09 SERG). When I added the Premium Forks after 2-3k, the ride / handling was exponentially improved!!! (once everything settled in about 1k)
For any good motorcycle suspension, the front & rear have to play well together...
Old Oct 7, 2014 | 09:34 PM
StrGlide's Avatar
StrGlide
I ride on Legend Suspension Revo coil spring shocks. They ride like a dream. The Revo uses a much longer spring than most shocks and that provides a larger "sweet spot" in the ride. They are made in Sturgis, SD USA as well.
Old Oct 8, 2014 | 06:48 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I used to work with a Man that said "Big Women are like big cars - they both ride good". That would probably give you the cushy ride you seek!
Old Oct 8, 2014 | 07:00 AM
gonenomad's Avatar
gonenomad
I am 165 and I have them backed all the way out. Riding Solo they are only a small improvement. However, riding two up, they are an enormous improvement.
I have the 12" premium shocks.
