K&N air filter?
Old Apr 11, 2007 | 08:26 PM
hangnman's Avatar
hangnman
Default K&N air filter?
Is it worth the $$ for the upgrade?
Old Apr 11, 2007 | 08:37 PM
mrsr71's Avatar
mrsr71
Default RE: K&N air filter?
Yes
Old Apr 11, 2007 | 08:53 PM
hangnman's Avatar
hangnman
I guess I am looking for the benefits from those who have these and the noticeable results
Old Apr 11, 2007 | 09:47 PM
Ben U
Guest
Posts: n/a
More air, you clean and replace saving you money and easy to do. Cooler running bike after you get the new download. Get a TFI or PWIII, then you can get the reprogrammed when ever you make a change to your ride ... and you will make changes.
Old Apr 11, 2007 | 10:04 PM
SoCal_Pappy's Avatar
SoCal_Pappy
YES to all of the above - Better choise for your BIKE, CAR, TRUCK, BOAT and anything else you can put it on...
They BREATH BETTER - and are cleanable so in the long run can save you $$$
Old Apr 11, 2007 | 10:07 PM
Indianspringsaz's Avatar
Indianspringsaz
You should get an A/C. You bike will run better. You will have to re-tune your SERT
Old Apr 12, 2007 | 02:44 PM
chiabate's Avatar
chiabate
K&N's are the most cost efficient way to improve power/mileage after pumpin' enough PSI's in your tires!
Old Apr 12, 2007 | 06:31 PM
mariner227's Avatar
mariner227
K&N is American made. Arlen Ness Big Sucker is not. K&N is better quality too! MY opinion.
Old Apr 12, 2007 | 08:38 PM
hangnman's Avatar
hangnman
OK went and bought new K&N filter...ready to make easy upgrade...taking off old SE filter one of the studs came off instead of just the torx nut...tried and tried but had to destroy old filter to get good grip on both stud and torx..bummer wanted to keep old filter...had to use vise grips and lots of heat to seperate the two..WTF nothing is easy..anyway new filter is installed!!! I will give my review of the upgrade if it ever warms up here...thanks for all the advise!!
Old Apr 12, 2007 | 09:25 PM
harleybob's Avatar
harleybob
I have the sert and had the bike tuned. I want to replace the screaming eagle air cleaner with the K&N air cleaner. Do I need to get the bike retuned ? Thanks. bob.
