What am I doing wrong?
Old Oct 28, 2014 | 08:53 AM
hogcowboy's Avatar
hogcowboy
These puppies are the best $15 I ever spent.
Just noticed those are out of stock but
Amazon Amazon
has anodized ones too.
Old Oct 28, 2014 | 11:06 AM
AnotherBlackSG's Avatar
AnotherBlackSG
Just noticed those are out of stock but Amazon has anodized ones too.
I agree. I had those installed when I had tires changed last year. Before it was a major PITA to check/add air. But now, it's really easy.
Old Oct 28, 2014 | 11:15 AM
472viper's Avatar
472viper
The HD valve stem hose comes with it's innards threaded in too far. Get a valve stem tool and turn the innards out about 3 turns and it will work like a champ.
Out of the package the innards will not compress the inside of the stem enough to allow air to enter the tire.
Old Oct 28, 2014 | 11:19 AM
CaptainKirk's Avatar
CaptainKirk
My HD one works great! I bought it and the HD gauge. The gauge would not seal properly and I returned that! But the extension works perfectly.
Old Oct 28, 2014 | 01:35 PM
semiret's Avatar
semiret
Don't waste your money
Mine sealed OK and seemed to work, but when I checked the air pressure in the rear tire, the gauge showed 40 lbs using the extension, but only showed 34 lbs not using it.
Old Oct 28, 2014 | 01:47 PM
roadking2014's Avatar
roadking2014
accu gage EZ air. A real time saver.
use the EZ air to check the pressure and fill with an air hose if needed.
you know if you roll the bike until the air valve is below 8 and 5 oclock you can find it with your hands instead of wallering on the ground to look at it to check.
Old Oct 28, 2014 | 02:24 PM
dirtdobber's Avatar
dirtdobber
I use this, works on all tire valves. A real problem solver.
http://www.gemplers.com/product/30A/...0141028192123s
Angled valve stems work good to. I have always used this, got mine at a station that closed in the 1970"s. The angled locking is all you may need. Just slide it on lock it and your done. You can add the rubber hose on most air chucks that screw off.
Backdraft161
Mar 3, 2018 06:52 AM
motocat13
May 25, 2013 11:41 PM
Terrabella
Sep 22, 2012 11:40 PM
milesvdustin
Oct 18, 2011 09:33 AM
Ogre3239
Aug 27, 2009 11:18 AM
