big sucker a/f
Old Oct 29, 2014 | 10:16 AM
strtglde11's Avatar
strtglde11
Default big sucker a/f
I just installed a big sucker filter, not running a cover. just left open. My question to you that are running same set up is when washing your bike do you use a rain sock, zip lock bag or anything to cover to keep water out?
Old Oct 29, 2014 | 10:19 AM
96roadking's Avatar
96roadking
I have mine covered but when hosing off the bike I have it running then shut it off to dry.
Old Oct 29, 2014 | 10:33 AM
jefla's Avatar
jefla
I recently switched back to an SE backplate and open filter, much like the big sucker (not in sig pic). I have not been covering mine, but after reading evil things about the TCA conection at the throttle body and unexpected limp mode, I'm going to start covering both with a shower cap.
I use very low water presssure. Basically I get it wet then use a sponge, then rinse. I always ride it until it's hot after washing.
Old Oct 29, 2014 | 10:47 AM
h-d wrencher's Avatar
h-d wrencher
I am running the same setup and I just try to avoid spraying water directly at the filter. No problems in 2 years of doing it that way.
Old Oct 29, 2014 | 12:13 PM
cprking's Avatar
cprking
6th Gear
I have same set-up . I Use zip lock bag, used this method for years with no problems.
Old Oct 29, 2014 | 12:23 PM
RaceFace's Avatar
RaceFace
Mine is open and I bag it up when washing the bike. I've been caught in a couple of unexpected downpours and worried about it, even posted it up here, and the consensus was that the water coming though wasn't enough to mess anything up while I am at speed in the rain. I don't ride in the rain by choice, but I haven't had an issue the couple of times that I had to.
Old Oct 29, 2014 | 12:45 PM
mkguitar's Avatar
mkguitar
put bags over the intake, exhaust and cover any electronics.
bucket and sponge allows you to feel any loose parts
never a pressure washer- ever.
use that on the driveway
mike
Old Oct 29, 2014 | 12:54 PM
casique's Avatar
casique
Gallon bag over the filter, if I remember. Four years no issues.
Old Oct 29, 2014 | 01:19 PM
crimson13's Avatar
crimson13
I used a gallon zip lock bag over the filter , use penatrox on the tbw plug to keep moisture out and to keep the pins from corroding.
Old Oct 29, 2014 | 01:33 PM
jefla's Avatar
jefla
Originally Posted by crimson13
I ...use penatrox on the tbw plug to keep moisture out and to keep the pins from corroding.
Crimson -- Do you use Penetrox in addition to or in lieu of dielectric grease on the pins?
