Electrical Problem on my UltraClassic
Old Apr 13, 2007 | 01:54 PM
locolobogzrgld03's Avatar
locolobogzrgld03
Stage III
Default Electrical Problem on my UltraClassic
I have a phantom electrical problem that the shop can't find the cause. I've heard of other riders having the same problem/results. Would like feedback if anyone has found the "cause" to the problem. My bike will be running perfectly at any speed or even just idling in the driveway, and suddenly, everything goes dead...electronics, engine, EVERYTHING. Each time within a few seconds, to a couple of minutes, everything comes back up and we are off and running. Purrs like a kitten on steroids. The main circuit breaker has been replaced twice, the battery is less than a year old and good. Any ideas???
Old Apr 13, 2007 | 02:04 PM
Szmytty's Avatar
Szmytty
Default RE: Electrical Problem on my UltraClassic
What year? I wasn't having any problems, but I just got my Voltage Regulator replaced for free from HD due to a recall for 06 Touring Motorcycles. The symptoms sound similar. Have you taken it to an HD Stealer or a private shop to check it out?
01 Suzuki Hayabusa
78 FLH with 93" Stroker
06 Street Glide
-Reinharts TD's
-TVII
-SE Air Cleaner
Old Apr 13, 2007 | 02:05 PM
Silverearl's Avatar
Silverearl
sounds like the computer module has a problem or the main switch. Wasn't there a recall on it??
Old Apr 13, 2007 | 02:52 PM
berettag's Avatar
berettag
I had a similar problem on a Low Rider (during the AMF years). I could be riding along and everything went dead, and I do mean everything. Then it would start up and run alright for awhile and do it again. Spent a few times in the dark on the side of a country road trying to find the culprit. Turned out to be the ignition switch shorting out against the rear fender and opening the circuit breaker. Fixed it by putting a rubber patch on the fender in that spot. They've moved the switches now, obviously, but the principle is still the same. Something may be shorting against the frame when you vibrate just right. Look for the problem where you least expect to find it. Good Luck. George
Old Apr 13, 2007 | 03:43 PM
locolobogzrgld03
Stage III
My Ultra is an '03. The shop checked the ignition switch and everything else they could think of and still are unable to locate the "cause".
Old Apr 13, 2007 | 03:45 PM
locolobogzrgld03
Stage III
There was a recall on the main circuit breaker, but my bike had already had this done. Now it has had the breaker replaced again, twice.
Old Apr 13, 2007 | 10:18 PM
Lpye's Avatar
Lpye
I had a similar problem years ago. The main switch finally gave up the ghost. Replaced it with a new switch and never had the problem again.
Old Apr 14, 2007 | 12:06 AM
Ultra 99's Avatar
Ultra 99
I had the same problem and traced it to the connection wherethe ignition switch plugs into the main harness. The connectors had started to turn green with corrosion and they weren't always making solid contact. Cleaned things up and put in some dielectric grease and everything's been fine since.
Old Apr 14, 2007 | 12:54 AM
Rollon's Avatar
Rollon
That's what it sounds like to me, a corroded connector or ground. Check all of the connections you can easily do. Look for oxide, white powder on the aluminum connectors or any built up of residue on the copper connectors. As for the connector to connectors, just hope it's not in one of those suckers! But, most likely is the ground connections.
Old Apr 14, 2007 | 05:34 AM
BigTom's Avatar
BigTom
Mine has had the same problem since new. Main breaker changed 3 times. Dealer can't (wont) find anything wrong.
