Battery terminal extensions?
Old Nov 3, 2014 | 07:33 PM
SPECIAL ED's Avatar
SPECIAL ED
Default Battery terminal extensions?
Ok this is the second time I've had to fuss with the battery on my FLHTK and I hate it.Yes it's my own damn fault I left the ignition on acc and drained the battery but what a PITA it is to get to that damn thing with some jumper cables or a charger.Has anybody ever made some extensions that could come out maybe under the side cover that you could easily attach clamps to?Even if they were coiled up under the seat it would be better that trying to hold all that plastic and wiring out of the way while trying to attach clamps to the terminals.I was thinking some heavy gage wire with a couple of those flat loop things on each end 1 end attached to the battery terminals the other with some kind of rubber boot to keep them from grounding out or arcing would this work?
Old Nov 3, 2014 | 08:35 PM
Ragtop's Avatar
Ragtop
You need a battery tender/charger. They come with pigtail leads that you can route to an easy place.
I have mine attached with velcro right in front of the side cover, on the frame.
However those pigtails should only be used for charging the battery, not to jump start the bike with.
Here is the one I use.
Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive Amazon.com: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger: Automotive
You can also use the positive connection on the starter to attach your jumper cables to.
Old Nov 3, 2014 | 08:50 PM
mkguitar's Avatar
mkguitar
so you jump your bike and start it and off you go.
here's the problem:
not only is your charging system keeping the bike running, but it is also trying to charge up a duff battery.
It is easy to stress the stator or voltage regulator and destroy them.
so a minor problem becomes a $600 fix.
Something to consider.
2.) most tender cables will ( and should) have a fuse in them. The power required to jump start a bike would far exceed the
rated fuse....the wire itself would probably melt at about 4 amps.
OP, the + battery cable goes to the starter, that is where you could ( after considering) attach the jumper cable- attach the other to a chassis ground.
adding a cable as you propose is a great idea until it somehow contacts the frame and short out, causing a fire.
and finally...a battery once discharged will only recharge to about 60% of it's previous capacity.
Your battery is probably on it's way out having been discharged a couple of times.
pull it, charge it with a battery charger ( not a tender) and load test ( free at autozone)...if you battery is dying then it is a constant load on the charging system
Mike
Old Nov 4, 2014 | 11:24 AM
Mike_M's Avatar
Mike_M
There's a number of solutions out there.
For $20 you can get one from Cyclenutz that will also allow you to plug in your battery tender or heated gear.
Old Nov 4, 2014 | 11:33 AM
UltraNutZ's Avatar
UltraNutZ
I've used these before and tucked it under the side cover.
http://www.ningbo-electric.com/power...onnectors.html
Old Nov 4, 2014 | 12:11 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Looks like trouble to me ! "O"Know
Old Nov 4, 2014 | 01:22 PM
0ldhippie's Avatar
0ldhippie
Here ya go
http://www.zoro.com/i/G4141907/?utm_...zumRoCDo7w_wcB
Old Nov 4, 2014 | 01:27 PM
Ragtop's Avatar
Ragtop
Originally Posted by 0ldhippie
$338? I don't think so..LOL
Old Nov 4, 2014 | 01:29 PM
UltraNutZ's Avatar
UltraNutZ
now that's funny! $338 set of jumper cables....
Old Nov 4, 2014 | 01:30 PM
mkguitar's Avatar
mkguitar
the zoros are what you might see on a tow truck or plow.
25' cable with clamps
Mike
