Exactly not a lubricant it's a penetrate, people are using it to lube things that should never have it on where it is being put, it will actually wash lubes out.
Not a lubricant...not a penetrant...it's a WATER DISPLACEMENT material. Works very well for that. You are correct in that it will wash lubes out, but it does something even worse...it will prevent real lubricants from attaching to the surface you want lubricated. If you have points ignition on a vehicle and you need to get the water out of it, WD40 is the stuff you want. It has no other use in my workshop.
My understanding is that newer bikes, and yours qualifies, have teflon coated cables and SHOULD NOT be lubricated. Also, aside from a possible mis-adjustment by the tech, the type of oil in the primary could make a difference. I had problems with Syn 3 and as soon as I changed it out all was well.
^^+1 my neighbor used Dri-Slide on his 2013 Limited and after a couple hours it gummed up so badly he had to pull into a dealer and pay the shop $50 to flush it out. New cables are Teflon coated - not sure which year they started this on though. I know my '05 was the older style and Dri-Slide worked great in it.
thinkin the same thing...a quick oil change in the primary mixing old with new can cause more slipping than assuming the tech did a full adjustment and messed it up.
I hate the stuff.
that was true years ago when it had the rocket on the can. (WD40-water displacement on the 40th try) Now its marketed as a lubricant to be competitive.
Agreed. As I stated, there are certianly better products to free up gummed up clutch cables than WD40, but I just cut and pasted the "lubricant" statement from their own website. I'm sorry guys, but if WD40 says THEIR product is a lubricant, I'm going with..... it is.
No matter, it will still cut out and dislove whatever is causeing the cable to bind, and have a crappy pull. So for that reason, it has worked for me countless times in the past.
