Battery tender plug in
Old Nov 18, 2014 | 05:29 PM
ultraclassic53's Avatar
ultraclassic53
Default Battery tender plug in
Decided it was time to hook up my battery tender on my 2013 cvo road glide. Looked all over and couldn't find it hanging anywhere. My non cvo road glide had it hanging next to the frame. Is it possible my expensive cvo didn't come with one ?
Old Nov 18, 2014 | 05:49 PM
senna's Avatar
senna
It's not a factory installed item, some dealers install them as a courtesy during pre delivery inspection.
Old Nov 18, 2014 | 05:50 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Many dealers install them on the bikes.
Perhaps yours did not.
Most pigtails dangle above or near the oil dipstick, right side.
Old Nov 18, 2014 | 05:54 PM
RushKing14's Avatar
RushKing14
I can't speak for the 13's, but the 14's came with one inside the left cover where the fuses are. My dealer pulled them out and put them along the rear rail before delivery, but it was a factory installed item.
Check your owner's manual as mine shows it inside that cover from the factory.
Old Nov 18, 2014 | 06:28 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by RushKing14
I can't speak for the 13's, but the 14's came with one inside the left cover where the fuses are. My dealer pulled them out and put them along the rear rail before delivery, but it was a factory installed item. Check your owner's manual as mine shows it inside that cover from the factory.
13s not factory installed. As stated, many dealers do it.... My dealer is not one of them. 14s HD incorporated into harness
Old Nov 18, 2014 | 06:30 PM
ultraclassic53
That's what threw me off. My 13 glide had one, my bike before it had one, my 14 limited has one. Couldn't believe my cvo didn't have one .
Old Nov 18, 2014 | 06:36 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Got mine from the factory
Old Nov 18, 2014 | 10:37 PM
oct1949's Avatar
oct1949
our dealer always installs one on all new bikes sold..
Old Nov 18, 2014 | 10:44 PM
hanny's Avatar
hanny
pull the left side panel off and see if its there, if not then looks like you need a pigtail which is pretty cheap to do and bet your dealer has one for cheap
Old Nov 18, 2014 | 10:47 PM
ynots's Avatar
ynots
When you buy a tender it will come with the pigtail
