compensator question
Old Nov 19, 2014 | 06:01 AM
harley7316's Avatar
harley7316
Default compensator question
Bought a used 2011 street glide i read that HD started to put in SE compensator from factory is that correct and what year did they start doing that.Thanks
Old Nov 19, 2014 | 07:15 AM
mrfikser's Avatar
mrfikser
I think in 11 they put in the se comps. only in the 103 models...I could be wrong though...
Old Nov 19, 2014 | 08:33 AM
harley7316's Avatar
harley7316
Well that would be my luck as my 2011 is a 96
Old Nov 19, 2014 | 08:38 AM
brian97's Avatar
brian97
6th Gear
My Wifes 2011is a 96 and it came with a SE compensator from new.
Old Nov 19, 2014 | 08:50 AM
Weavr99FLHT's Avatar
Weavr99FLHT
96 and 103 in 2011 got upgraded comp assembly 83935-09 as stock. I think 12 got -09A .
Then 14s upgraded again.
Old Nov 19, 2014 | 09:04 AM
harley7316's Avatar
harley7316
Good to know thanks for the help
Old Nov 19, 2014 | 09:24 AM
REPO1's Avatar
REPO1
Out of curiosity, do the newest versions (2014+) fit onto a 2008?
Old Nov 19, 2014 | 09:46 AM
SBates08's Avatar
SBates08
Yes
2010 Limited with some stuff!!
Old Nov 19, 2014 | 10:10 AM
btsom's Avatar
btsom
With the qualification that if you are replacing the stock comp, you also need a new style rotor to go with the new comp. The old style with the welded in coil spring is not compatible with the belleville springs. To the OP, go to a source with exploded parts diagrams for YOUR bike (http://www.shopronniesharleydavidson...REAR|~WHEEL\FR) is popular, and see if the diagram shows the belleville springs. They are very large, curved "washers" between the compensator and rotor and ONLY are used with the SE style comp so they a dead giveaway.
hogginit
Jun 24, 2013 11:37 PM
SG108
Nov 28, 2012 07:00 PM
cruzmisl
Sep 10, 2012 01:05 AM
jbmss
Aug 14, 2011 04:57 PM
crazzy76
Jun 29, 2011 06:17 PM
