Shift Pawl Spring replacements
Old Nov 25, 2014 | 11:05 AM
TSheff's Avatar
TSheff
Default Shift Pawl Spring replacements
I have a 97 FLHR that has excessive slack in the shift linkage, There is some movement in the foot shift shaft and the bearing/bushings need to be replaced. the bigger issues seems to be the amount of travel on the transmission shaft without any tension. I bought the bike a month ago and have been sorting out issues and have no idea how many actual mile it has. The total travel may not bee to much and the bike shifts and is rideable.
I'm thinking the spring on the shift pawl are gone.
Can they be inspected and/or replaced without removing the transmission.
Old Nov 25, 2014 | 12:28 PM
harleytuner's Avatar
harleytuner
Short answer NO, but make sure the shifter arm isn't worn out, or the allen bolt isn't loose before you get to carried away.
Old Nov 25, 2014 | 01:10 PM
tfi racing's Avatar
tfi racing
I had to replace the shift pawl on my last bike (came off the shaft inside the transmission), nothing to it - just remove all the primary,
Pull the guts out of the trans, replace $17 part then totally reassemble.
The best part is, I had to replace the stator about two weeks later. ..
Old Nov 25, 2014 | 01:43 PM
harleytuner
Right, I was answering his question weather or not he has to tear into the trans, which he does. But I have also seen the link arm bad as well.
Old Nov 25, 2014 | 08:59 PM
TSheff's Avatar
TSheff
Thank You. I'll check and double check before I open it up.
Old Nov 25, 2014 | 09:56 PM
btsom's Avatar
btsom
That rear arm on the transmission shift shaft is about the most common loose item on recent Harleys.
Old Nov 26, 2014 | 03:18 PM
0ldhippie's Avatar
0ldhippie
If the pawl spring inside breaks it won't shift normally. Shifter will lay there. More likely ya have bad/loose splines on linkage.
Old Nov 26, 2014 | 10:45 PM
Fishrrman's Avatar
Fishrrman
Old hippie has the answer.
I had the shifter spring break once - the shift lever will drop down to the depressed (downshift) position and stay there. Not "mushy" -- just goes to the bottom and that's it.
I've also had a bike where the shift arm becomes loose on the transmission shaft. That's where the "loose, mushy" feeling is coming from.
Old Dec 5, 2014 | 10:34 PM
TSheff's Avatar
TSheff
Rear shift arm was the problem. Appears someone put loctite RED on the tension stud but didn't tighten it fully. Bolt would not move but arm was sloppy which allowed it to wear a little. Finally broke the bolt loose cleaned it and properly tightened, So MUCH better.
Old Dec 6, 2014 | 03:17 PM
el loco rico's Avatar
el loco rico
There used to be an adjustment procedure for the shifter pauw. You loosen Allen bolt and set the pauw center of slop.
Dynafrom818
Apr 8, 2019 04:31 PM
Crashone
EVO
11
Jul 3, 2015 10:06 PM
Rnt77
Jun 17, 2013 07:18 PM
Hoblick
Aug 29, 2011 09:32 AM
elauee1
Jul 11, 2010 05:03 AM
