Rinehart Baffles Replacement
Old Apr 15, 2007 | 12:08 AM
Taterdog's Avatar
Taterdog
Default RE: Rinehart Baffles Replacement
ORIGINAL: LOU
Will changing the baffles or wrapping with fiberglass require another download?
I don't think so, Lou, but maybe someone with more experience can give some feedback. If anything I would think it might run slightly richer, but not by much.
Old Apr 15, 2007 | 10:39 AM
truegentlemann's Avatar
truegentlemann
From: i live outside Omaha Ne on the Iowa side in the Loes hills, some great places to ride
so what you guys are saying is that there is no packing on the Reinharts as you receive them?
i have a set and a motor biuld and they are wild loud.
my hot rod buddy lives in a nice neighborhood and has even asked me to not get on the throttle when i leave his place it is so loud.
i don't want quiet i just dont want a ticket.
Old Apr 15, 2007 | 11:04 AM
Taterdog's Avatar
Taterdog
All I'm seeing is perforated metal inside perforated metal. If you go to the Bub website and check out the FAQ's, they recommend wrapping them with fiberglass to really quiet them down. Again, the one I read from the Bub rep said he thought they sounded best wrapped. Guess that's something I need to learn how to do!
Maybe that's the secret to not waking up the neighbors.
Old Apr 15, 2007 | 11:26 AM
LDrider's Avatar
LDrider
I have the quiet baffels in mine and often ride with a friend who has the standard ones. The difference is very noticable. I would try them without the fiberglass at first.
Old Apr 15, 2007 | 11:37 AM
old558's Avatar
old558
Im also interested in how these work for you. I think mine are a bit loud and was thinking about wrapping them. You can pick up fiberglass wrap at any place that sells dirtbike stuff.
Old Apr 15, 2007 | 11:41 AM
Taterdog's Avatar
Taterdog
Another question. The fiberglass wrap, is it the 2" wide tape I see that can be used to wrap the exterior of an exhaust header, or is it the sheet of fiberglass material normally used as packing? I can probably find something today at an auto parts store.
Old Apr 15, 2007 | 12:25 PM
Fandango6's Avatar
Fandango6
I repaced my stock baffles for the quite ones after doing a 98" build as the stock Rinehearts got close to being obnoxious. I noticed a big difference in sound and torque. They are now quiter that before the build w/ stock baffles. Mine are the earlier version mufflers acouring to Eastern Performance were I bought them, They had been in for 20K miles. Had to grab the ends with a vice grip and get them wiggling side to side and they came out w/o to much effort.
Old Apr 15, 2007 | 02:34 PM
wnogood's Avatar
wnogood
ORIGINAL: Taterdog
The packing you want is similar to the insulation you put in your attic only a bit more robust. It is actually designed for exhaust applications. I have not tried it on a street bike, but I know it makes a big difference in a 2 stroke silencer. I would imagine that it would really quiet down the Rineharts. I would try the quiet baffles first, because the packing will disintegrate over time. I guess what I mean is if the baffles suit you, the sound will not change much over time where the baffle packing will have to be redone occasionally.
nogood o~`o
Old Apr 15, 2007 | 11:41 PM
Taterdog's Avatar
Taterdog
So, will something like this work to wrap the baffles with? Found it in the McMaster-Carr catalog. 1/8" x 3" x 25 feet is $44.64. Anyone have another source for this type of material that might be cheaper?
Ultra-High Temperature Strips
Temperature Range: -50° to +2300° F
Heat Flow Rate (K-factor): 0.48 Btu/hr. x in./sq. ft. @ 800° F
Density: 12 lbs./cu. ft.
Color: White
This insulation is made of alumina oxide fibers, making it resistant to molten metal sparks and splashes.
1" x 50 ft. 2" x 50 ft. 3" x 50 ft.
Thick. Each Each Each
1/32"
87575K81 $13.59
87575K82 $18.56
87575K83 $23.10
1/16"
87575K84 17.59
87575K85 26.07
87575K86 36.14
1" x 25 ft. 2" x 25 ft. 3" x 25 ft.
1/8"
87575K87 $20.00
87575K88 $32.07
87575K89 $44.64
Old Apr 16, 2007 | 01:43 AM
truegentlemann
I took some fiberglass out of a set of Vance & Hines on my last bikes slipons. that is what i was thinking of using.
that stuff was about 1/2 in thick and about 12" wide and long enough to go around the baffle.
and as some one else said i am sure you could get it at the local dirt bike store.
