Rinehart Baffles Replacement
Old Apr 4, 2008 | 09:29 AM
  #31
pdexter's Avatar
pdexter
Default RE: Rinehart Baffles Replacement rattle
rinehart rattle, i too had a rattle in the right pipe ( new style true duel ), this fix is NOT in the service manual but it worked in that i could not get the three fastners out.
i took an oar from the small boat i have and it fit exactly into the baffle, the hand end is the perfect tapered round size and i simply tapped it in to seat it and moved it side to side. fixed
and i didnt have to disconnect the negative on the battery
Old Apr 4, 2008 | 03:58 PM
  #32
drrandall1's Avatar
drrandall1
I am getting the rattle noise. My rinehart true duals were fine then I installed the high performance baffles and now I get the rattle noise on decel
Old Apr 26, 2008 | 06:22 PM
  #33
Firedog's Avatar
Firedog
6th Gear
Is there any need to get a dyno after removing the baffels now that the exhaust restriction. will this also effect the heat build up?
Old May 9, 2011 | 09:38 PM
  #34
LoneGrey's Avatar
LoneGrey
Taterdg -- lets fast forward to 2011. I bought a 99 Road Glide last year and had Rinehart TDs already on it. It was loud. I fieberglass wrapped them. Helped a litte but not much. I have read hundreds of posts here and elsewhere trying to figure out what kind of quiet baffles I needed. Your post, describing the old and new versions was PERFECT. Thank you sooo much. Now all I have to do is find them. Again, many thanks.
bmaier
Jul 13, 2011 07:49 AM
Wineguy
Nov 17, 2008 07:01 PM
Glyde
Exhaust System Topics
Jul 28, 2008 06:56 PM
SkyDriver
Oct 8, 2007 10:53 PM
Romark
Jun 10, 2007 12:47 AM
