Rinehart Baffles Replacement
I've got the newer style Rineharts (in case you wonder what you've got, the new ones have three screws holding the end cap on -- the old ones only have two). I damn near beat the end cap to death until I realized there was another screw on the bottom!
Jim Rego with Bub was a BIG help in getting me info that I needed to replace my stock baffles with Quiet baffles, including how to wrap them to make them a little quieter. Here's what Jim had me do:
1. For the newer style TD's, the baffles look different from the ones for the older style TD's. The new style has a venturi flow restriction built into one end of the baffle, whereas the old style has a ring, or doughnut, on one end. When you look at the stock baffle and new 2" Quiet baffle, they look the same on the outside and are the same pipe sizes, but the Quiet baffle has a 2" inner pipe which provides additional restriction and quieting. The venturi on both goes in the front of the muffler, and since both ends are different sizes, the baffles can only fit one way, so you can't screw it up.
2. To remove the end caps, first remove the screws (all of the screws), then spray the joint between the endcaps and the mufflers with Windex to provide some lubrication. Next, support one side of the end cap with your hand and rap the other side with a rubber mallet. The end caps are pretty tough, so as long as your using a soft head mallet, don't worry about hitting it. Do this all around the end cap and it will slowly back itself off. It's a tight fit and is being held on by both the muffler and baffle, so it will take more than a few taps to get it off. DO NOT use a screw driver to try and spread the end cap from the muffler; you could scratch both the muffler and end cap that way.
3. Once you have removed the end caps, Jim told me to use a sliding hammer with a hook on one end to remove the baffles, but neither of mine was that tight and I was able to grab them with some pliers, wiggle back and forth slightly, and they pulled right out. If you have any trouble, you can always use the sliding hammer method hooked to the penetrations in the baffles to back them out.
4. I wrapped my new 2" Quiet Baffles with fiberglass before installing them, so don't know how they would have sounded without the wrapping. They are still loud, but not too loud and actually are about right for me. When cruising at steady speed they are not loud at all, but when you get on the throttle they still have a bark, albeit a muffled bark. At highway speed they are a good sound, still a little loud, but not so much as to interfere with the radio. For me they are about right so that cars around me know I'm there.
5. To wrap the baffles, get some fiberglass repair sheets (I found some Bondo material that worked great -- it was packaged in 8 sq. ft. pieces, and I used two packages per baffle). Wrap the fiberglass around the baffles and secure with steel wire. I used 20 gauge stainless steel wire to wrap multiple times around the fiberglass. Some suggested using steel wool instead of fiberglass, which would be a more permanent setup, but I could not find steel wool in other than pads, so went with the fiberglass.
6. Once the baffles are wrapped, just insert into each muffler, tap in place (use a piece of wood over the end of the baffle to protect the end), then reinstall the end caps with the rubber mallet. Once in place, reinstall the screws (I added some Locktite since they'd had something on them before).
Pretty simple mod actually, once Jim Rego, myself, and Mark at M&M Cycle figured out what I had and what type of baffle I needed. My Rinehart TD model number is 1800-0242, and the 2" Quiet Baffle model number is 1861-0332. Bub had changed some part numbers when they came out with the new style TD exhaust, and some vendors have been confused over what goes with w
nogood o~`o
Now on to the next bike project -- getting my PCIII map tweaked. Guess I better mow the yard first, though, starting to lose the dachshounds in the tall grass!
My question is will it still work in my Rinehardts? I should be able to go back to the dealer and get them to give me the right ones. I have only had them for one week. I am not too happy with the sound of them anyway. It went from this deep sound to a higher sound.
Travis
Looks like my dealer installed the wrong quiet baffels for my Rinehardts. I have the newer Rinehardts and they installed the old style baffels. The dealer even told me when he installed them he had to cut them down to make it fit. Charged 1 hour of labor to install the baffels.
Travis
This has been a very helpful thread. I'm not replacing my Rinehart baffles but I have one rattling in the right pipe. Drove me crazy in Daytona and I've been putting off fixing it because I didn't know what I needed to do. I don't think I will have a problem now.
