error code P0134
Old Nov 30, 2014 | 03:53 PM
bigtwin1228's Avatar
bigtwin1228
Default error code P0134
I have a 13 Road Glide since adding the Vance and Hines true duals with Rhine hart exhaust. It throws a P0134 code which has to do with the 02 oxygen sensor and then a PN32999-11. Is the PN32999-11 the part number? if I do a search on the net or at HD.com I get nothing. will replacing the 02 sensor solve the problem? The bike seems to run fine it just doesn't feel right it's hard to explain when going down the road it kinda feels like something is holding it back, when I get on it it acts like it should. Could the 02 sensor being bad cause this feeling?
Old Nov 30, 2014 | 04:02 PM
lp's Avatar
lp
The PN thing is normal. It's the pn for the ECU or something I forget.
Anyway, be sure you connected the O2s correctly, at the right places, and that if you're using eliminators, they are connected tight etc.
What tuner are you using?
Old Nov 30, 2014 | 04:05 PM
bigtwin1228
No tuner
Old Dec 3, 2014 | 01:20 PM
semiret's Avatar
semiret
Never mind. lp already said what I had
Old Dec 3, 2014 | 02:10 PM
dforeid's Avatar
dforeid
Your O2 harnesses are both plugged in behind your right side cover properly, right? The wires appear to be intact OK at the O2 end? Is that all that was done to the bike - just new pipes? Did you do the work, or a shop?
Old Dec 3, 2014 | 05:21 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
didn't get the plugs on the wrong sensor?
Old Dec 4, 2014 | 08:58 AM
semiret's Avatar
semiret
You also want to make sure the pins in the O2 sensor connector are not pushed back a little. This was mentioned in the electrical diagnostics manual, so it might be a relatively common occurrance
Old Dec 4, 2014 | 09:16 AM
JustDave13's Avatar
JustDave13
P0134: No O2 sensor activity.
Unplug them, check the pins, make sure you re-connect them properly, clear the code and test ride.
Old Dec 4, 2014 | 03:02 PM
Assegai's Avatar
Assegai
yeah, I'd start here for sure.
Old Dec 4, 2014 | 03:14 PM
Joe12RK's Avatar
Joe12RK
bike feels sluggish because the bike is in safe mode (rich, retarded) - but normal when you get on it because it's in open loop and O2 sensors not in the picture any more
bdtaylor1979
Apr 10, 2016 12:40 AM
Highgrade
Oct 1, 2015 06:57 PM
RustyCage
Aug 10, 2015 12:21 PM
sud55
Apr 28, 2013 01:40 PM
icebite1
Jan 18, 2012 01:23 PM
