blown fuse
Old Dec 6, 2014 | 01:55 PM
harleyman1999's Avatar
harleyman1999
Angry blown fuse
i can't figure out why i keep blowin the turn signal fuse when the bike is put on accessory or when i hit the horn switch and i have no brake light but all fuses are good,the bike is a 2006 streetglide 103 screamin eagle not fuel injected any more
Old Dec 6, 2014 | 02:00 PM
Teachinator's Avatar
Teachinator
Check for shorts to ground at the controls to your blinker switch. Have you changed out your handle bars? If so, you could have pinched or nicked some wires that controls your blinkers.
Good luck
PH
mkguitar's Avatar
mkguitar
if the fuse material is spattered inside the housing- or black carbon traces- then you have a short circuit.
if the fuse material appears to have just sagged and parted, then you have an overload.
...lowered bike? check the taillight wiring under the rear fender
Mike
Old Dec 6, 2014 | 02:10 PM
Tirpitz's Avatar
Tirpitz
Another place to look in inside the fairing on he left side where a wire loom goes over a brace for the fairing.
Old Dec 6, 2014 | 02:57 PM
Gunnysgt's Avatar
Gunnysgt
I'd check any accessories I've added for a short via frayed, damaged, or pinched wire. Sounds like a direct short.
Old Dec 6, 2014 | 05:11 PM
GTK's Avatar
GTK
Mike
Good info
Old Dec 7, 2014 | 09:11 AM
harleyman1999
Default Thanks!
Thanks so much brothers,i have looked and traced wires but still can not find the problem i have done alot of mods to bike,rims, lower,engine,cams,take fuel injection off,paint,brakes and so much more have decided to get it looked at thanks again ride safe!
t-bone 702
Electrical/Lighting/Alarm
13
Aug 13, 2016 09:46 AM
Smash
Sep 29, 2015 05:19 PM
UncleBigGeorge
Apr 20, 2014 11:16 PM
gmc
Oct 20, 2010 12:44 PM
brandanfinn
May 12, 2009 08:43 AM
