De-catted headpipe
Old Dec 12, 2014 | 10:18 PM
houstonhdguy's Avatar
houstonhdguy
Default De-catted headpipe
Suggestions on where to get best price on de-catted headpipe for 2011 King?
Been looking for something off of a 2009 with not much luck. Don't really want to spend a ton of money.
Thoughts?
Old Dec 12, 2014 | 10:45 PM
pacemakertom's Avatar
pacemakertom
I have a stock headpipe from a 2011 FLHTP.
Still has cat.
You can have it for just the shipping from NJ 08046
You can do it yourself and save money
Tom
Old Dec 13, 2014 | 12:07 AM
mkguitar's Avatar
mkguitar
otherwise look to ebay- seems about $150 is about right.
the 2009 would require o2 sensor bung adapters, and the location is not the same as yours- wires may not reach...also while most 2009's have not cat...some do. CA spec bikes often show up in other States
mike
Old Dec 13, 2014 | 12:36 AM
0ldhippie's Avatar
0ldhippie
I have the non cat header off my '09 I'll send ya for $150
Old Dec 13, 2014 | 01:02 AM
Crimson's Avatar
Crimson
Going price is about $130-150.
Old Dec 13, 2014 | 03:12 AM
94ruck's Avatar
94ruck
I am in DFW, i have one with a cat that I can de-cat for you. It doesn take a little while to cut if open, remove the catalyst and weld back shut. Can do it for a hundred...
Old Dec 13, 2014 | 07:35 AM
billnourse's Avatar
billnourse
It is easy enough to gut a cat if you have someone who can weld the window back in. Any welding shop will probably do it for about 20.00.
On the heat shield side of the head pipe measure in 3/4" from each end of weld in the collector, then make the window just short of where the radius starts on the sides of the collector. Cut out the window with a very fine metal blade. I use a dremel tool. Pry the window up and clean out the cat with a screwdriver. Get someone to weld the window back in.
Bill
Old Dec 13, 2014 | 08:51 AM
OLDDEADEYE's Avatar
OLDDEADEYE
Yeah, it's not too hard to gut yours, all you need is a cut-off tool to cut the hole, I had mine welded back up by a Muffler shop for 25 bucks.
I had pics, but I can't seem to find them.
Old Dec 13, 2014 | 10:20 AM
risuperglidecustomman's Avatar
I got mine from Flea Bay!
Old Dec 13, 2014 | 01:37 PM
OldPhat's Avatar
OldPhat
Go To www.fullsacperformance.com and check out their Sportpipe, it's done right and
is cheap enough, and will add a few horses.
