Compensator Going Bad?
Old Dec 19, 2014 | 05:01 PM
magellan's Avatar
magellan
Default Compensator Going Bad?
I have a 2012 Streetglide with 32,00 miles on it. It is totally stock. This morning after riding for 20 miles, I stopped for fuel. When I hit the starter button, I heard a loud single "bang" noise that came from the primary. I rode the rest of the day without reoccurrence of the noise. I am wondering if this is the compensator beginning to fail.
Old Dec 19, 2014 | 05:03 PM
Hogpro's Avatar
Hogpro
Former Sponsor
That is what mine did although it was fine until 19k miles. From that point on it slowly started to do it more and more often until it got the point that I could not deal with it any longer. You might want to look into the 2014 comp with a Compesnaver.
Old Dec 19, 2014 | 08:39 PM
btsom's Avatar
btsom
What lube are you guys using in your primaries? I have an 08 Road King and put the "Mark 1" SE comp on it in 09 at 15,000 miles. I now have 70,000 miles and the comp seems fine, smooth starts, smooth operation. I run the same type of oil in the primary that I put in the engine. My son has an '11 Road Glide Ultra with 25,000 and he has always run Mobil 1 V Twin in his engine and primary. His comp still seems in excellent shape also.
Old Dec 19, 2014 | 09:25 PM
saintdaniel's Avatar
saintdaniel
the baker compensator is what i am waiting for.
Old Dec 19, 2014 | 11:29 PM
texaswiz's Avatar
texaswiz
I think what you are describing is known as "kickback". Nearly every late model touring bike owner I know gets it from time to time. It is most pronounced when you pull in to get fuel and turn the bike off. The piston will always stop on the compression stroke. The bike is hot and during the 5 minutes it takes to gas up there is no leak down on the cylinder. So, when you hit the starter it has to struggle to overcome the built up compression and the result is a horrible knashing sound. It makes you look to see if there is a pile of metal below your engine the first time this happens. If you have a battery that is not quite up to 12.8 volts, that can contribute to the problem because it does not have enough "umph" to spin the engine without incurring the "kickback" sound. It also helps if you have a compression release so you don't have to overcome that initial start up pressure that you get from a hot engine. Some of the newer touring bikes come with compression releases already installed at the factory.
Old Dec 20, 2014 | 12:53 AM
dickey's Avatar
dickey
Texaswiz is 100% correct. Keep your battery charged & terminals tight, & it shouldn't happen.
Old Dec 20, 2014 | 04:29 AM
magellan's Avatar
magellan
Thanks for the info on kickback. I believe that may be the problem, as I do have a weak battery.
Old Dec 20, 2014 | 05:06 AM
sortasuave's Avatar
sortasuave
Another vote for "check the battery" I had that happen several times and had the battery die just before I was going to do the compensator. Once I replaced the battery, I've not had the problem again.
Old Dec 20, 2014 | 05:47 AM
Notgrownup's Avatar
Notgrownup
Yep, a weak battery will make some bikes act weird sometimes....
Big Dave
Jun 23, 2019 08:48 AM
Robbie74
Sep 1, 2018 05:37 PM
C908
Oct 13, 2017 09:38 PM
Jmccathern
Milwaukee Eight (M8)
May 11, 2017 08:26 AM
rlyons
May 5, 2008 10:00 PM
