Anyone peg 120 mph on glide
Old Jan 2, 2015 | 11:09 AM
Papa Joe's Avatar
Papa Joe
2014 Street Glide, slip-ons, a/c, fp3; I've had it pegged on several occasions. It takes it a bit to get there, but it will cruise 105 with no problems at all.
Old Jan 2, 2015 | 11:12 AM
Leftcoaster's Avatar
Leftcoaster
'06 SG. No it's not stock - yes it hits the 120 speedo mark regularly.
Old Jan 2, 2015 | 11:17 AM
IdahoHacker's Avatar
IdahoHacker
Originally Posted by TexasRoper
14 limited, 120 no problem , stay in 5th gear
Believe it or not, this ^^ really makes a difference.
Acceleration is the battle between torque and weight, but top speed is more a battle between horsepower and wind resistance, and the higher the rpm the more hp you've got. Lower gear is better.
As far as blowing something up...naah. If you've had your bike on a dyno for a 6th gear pull, redline is around 160 mph and it didn't blow up. It won't blow up at 120.
Once a stock motor hits 90 mph or so, things start to happen much more slowly, so as most have mentioned, it takes a pretty long run to get past 100 and keep climbing.
Then there's room for the "slowing down" part.
Old Jan 2, 2015 | 11:39 AM
fourburgs's Avatar
fourburgs
Stock 96 in. and GPS said 107 mph at poccono raceway
Old Jan 2, 2015 | 11:47 AM
KaponeWKYA's Avatar
KaponeWKYA
After some mods, 120 with NO problems...grab it all (in 4th gear) and hold on!
Old Jan 2, 2015 | 12:12 PM
mountain man's Avatar
mountain man
127 is my tops on the ultra. Still have it stored on the GPS as the discussion comes up from time to time.
Old Jan 2, 2015 | 12:14 PM
t. sawyer's Avatar
t. sawyer
07 st. glide stage one, 100 no problem, 101, looked like it was going to take awhile so I let off. good thing to , 3 deer walked out 1/4 mile down the road. I said thank you lord and I don't do that anymore!
kroozeabout.
Old Jan 2, 2015 | 02:06 PM
Egldr05's Avatar
Egldr05
Buried it easily several times. (120")
Rick
Old Jan 2, 2015 | 02:08 PM
SmittyFXDL's Avatar
SmittyFXDL
Before adding my cams it was hard to break 100, but I was always trying in 6th gear.
Added 48 cams and now can break 100 easily but 110 it just seems to get stuck in a time warp.
I was able to hit 115 with no wind and on a slight downhill coming across I-10 once.
Ill have to try leaving in 5th gear and see what happens. I think I did try that but it did not sound very good at all.
Old Jan 2, 2015 | 02:19 PM
SunCruise's Avatar
SunCruise
Yep, keep it in fifth and use really good straps so she don't fly off the trailer.
SC
