Cross over exhaust Pipes ..Why ?
Old Apr 16, 2007 | 11:47 PM
conch54's Avatar
conch54
6th Gear
Default Cross over exhaust Pipes ..Why ?
Dose anyone know the reasoning behind HD use of the cross over exhaust on the dual exhaust touring models , instead of a true dual like are sold by everyone? Just curoius....thanks... Luis in Miami.
[IMG]local://upfiles/28174/0F521A2931DC4057B0B2F6E9C4968246.jpg[/IMG]
Old Apr 17, 2007 | 12:04 AM
txfxstrider's Avatar
txfxstrider
Default RE: Cross over exhaust Pipes ..Why ?
Yes, but the answer is too long and complicated to type now. This info is available almost everywhere.
geargrinder's Avatar
geargrinder
Because an exhaust equalizer provides a broader power band on dual exhaust systems.
Old Apr 17, 2007 | 12:50 AM
wesd41's Avatar
wesd41
What geargrinder said, plus this- the only reason HD puts a left side muffler on the bike at all is so it looks balanced.
Old Apr 17, 2007 | 12:57 AM
Retired_Ted's Avatar
Retired_Ted
A crossover system provides a scavenging effect in that the exhaust from one cylinder provides some momentum in the exhaust system to help clear out the second cylinder - best example is a 2 into 1 system - they have the best dyno figures for our engines. By disabling the crossover system, we cut our power potential - most don't mind the power loss.
Old Apr 17, 2007 | 06:06 AM
RBJones's Avatar
RBJones
ORIGINAL: Retired_Ted
A crossover system provides a scavenging effect in that the exhaust from one cyclinder provides some momentum in the exhaust system to help clear out the second cylinder - best example is a 2 into 1 system - they have the best dyno figures for our engines. By disabling the crossover system, we cut our power potential - most don't mind the power loss.
Good explanation. True duals do look good and eliminating the crossover is nice. I think true duals can probably have as much power as anything else, but only at certain points along the power band. The misbalance between the pipes due to their different lengths is going to cause flat spots and dips along the torque and power curves regardless of what you do and you have relatively little control even by changing efi MAPs. You can't fight the laws of exhaust physics. But they do look good and if you've got wads of power to spare anyway, you're probably going to be very happy with them.
Old Apr 17, 2007 | 10:06 AM
HogBack's Avatar
HogBack
As the others said, the scavenging benefits are a real plus. Take for example the headers on a V-8, on a high performance application where they run WITHOUT the crossover muffler exhaust system, they get the important scavanging for the four cylinders on each cylinder bank with each header. Dynos show that an even better benefit is an equal length header tube design. A 2 into 1 is based on the header principal. IMO a crossover is a very good design to stay with when you go with an aftermarket dual exhaust.
Hogback
Old Apr 17, 2007 | 01:59 PM
zubaugh's Avatar
zubaugh
Here’s the best explanation I have found to date: http://www.harley-performance.com/harley-exhaust.html
ORIGINAL: conch54
Old Apr 17, 2007 | 09:14 PM
conch54's Avatar
conch54
6th Gear
Thanks for ALL the explainations ...it all make sense
RKC20030
Aug 5, 2013 06:42 PM
883Frankenbike
Exhaust System Topics
Nov 28, 2012 02:39 PM
dimefan
Jul 9, 2012 05:16 PM
Milwaukee_intern
Oct 17, 2008 04:12 PM
campdreamer47
Aug 29, 2006 10:31 PM
