Truck lite question
Old Jan 14, 2015 | 02:10 PM
bigjoe21's Avatar
bigjoe21
Default Truck lite question
I have searched and searched but I cannot find the answer. Does the Truck Lite need a load equalizer installed also? Or any other parts?
Old Jan 14, 2015 | 02:13 PM
Nute's Avatar
Nute
NO! Plug n Play. Couldn't be easier. You will probably have to play with the aim until you get to where it works just right for ya.
FYI! You would only need an equalizer on your signals should you go to LED with aftermarket LED's. HD don't require the equalizer.
Old Jan 14, 2015 | 02:14 PM
SeaZund's Avatar
SeaZund
no, the TL is a direct plugin. You only need the equalizer when changing your incandescent turn signal bulbs to LEDs.
Old Jan 14, 2015 | 02:19 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Plug and play, but you most likely will need to adjust to your liking.
sbeast's Avatar
sbeast
I have over sitting on the shelf right now, once I get a warm evening, its going in!
Old Jan 14, 2015 | 02:41 PM
bigjoe21's Avatar
bigjoe21
Anyone have a part number for a 2009 Street Glide
Old Jan 14, 2015 | 02:46 PM
SBates08's Avatar
SBates08
The phase 7 fits all. No particular part number for each year. 27270C.
2010 Limited with some stuff!!
Old Jan 14, 2015 | 03:22 PM
equandt's Avatar
equandt
No load equalizer required. It's a drop in replacement.
Old Jan 14, 2015 | 03:23 PM
decencyxdefied's Avatar
decencyxdefied
I believe this same question was asked last week
Old Jan 14, 2015 | 05:12 PM
bosshog919's Avatar
bosshog919
Like others have said no stablizer needed!!!!!!!
