Fork Locks but Ignition Doesn't
Old Jan 15, 2015 | 01:14 PM
wmarketst's Avatar
wmarketst
Stage II
Default Fork Locks but Ignition Doesn't
Hello
I've got a 2012 FLHTCU and I've got something goofy going on with my Ignition Switch/Fork Lock.
The switch seems to function normally and when in Fork Lock position and locked with key the forks remain locked as expected.
However the switch still moves to the off/ignition/access position and allows the bike to be started.
It appears the switch is not fully seating far enough down to keep the switch locked in the fork lock position.
Has anyone else experienced anything like this??
I've watched video on switch removal
www.youtube.com/watch?v=GMKo7zbiSBc
removed the switch several times & Checked alignment but the problem persists
Old Jan 15, 2015 | 01:27 PM
mikelikesbikes's Avatar
mikelikesbikes
I know it is a different arrangement but I had my Road King in Florida on a job assignment a few years ago, staying in a hotel when my ignition switch stopped working. Had to order another which took nearly 2 weeks to get in so I bought the best cable lock they had. Being as that your bike is as new as it is there may be something else going on.
Old Jan 15, 2015 | 01:30 PM
mkguitar's Avatar
mkguitar
welcome to the forums.
seems someone likely pulled the lock and alignment is out ( which can happen with a screwdriver----easy)
do over, make the tool from 1/4" copper tubing ( see youtube videos for specifics)
look into the hole with a flashlight and try to identify the cams and positioning.
I had to go to my neighbors house a while ago for similar complaint...I took my bike down so I could pull my switch and compare the cam alignment
mike
Old Jan 16, 2015 | 08:18 AM
wmarketst's Avatar
wmarketst
Stage II
Thanks Mike
I'll head to home depot
Any advice on making the tool (i.e. measurements, specifics)
Old Jan 16, 2015 | 09:28 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Or this for $25 bucks Harley Ignition Switch Tool
Old Jan 16, 2015 | 09:41 AM
senna's Avatar
senna
It seems to me that if your able to lock the forks and the ignition switches normally ( but doesn't lock ) that it is aliened properly in the two lower cams.
I would think the issue is in the switch head itself. like you mentioned "the switch is not seating far enough down to lock". I'd be looking at the switch itself.
Old Jan 16, 2015 | 09:47 AM
t. sawyer's Avatar
t. sawyer
there is an old thread on here about making that tool. found it , its called vedio of ignition switch removal. thats the tool I made and worked fine ...good luck.
kroozeabout.
Old Jan 17, 2015 | 07:06 PM
leon anthony's Avatar
leon anthony
look at the shaft that goes down in the switch you will see that the projections on one side are wider that the other side you have to line the groves in the switch so all the wide one are line up you probably have the bottom one one eighty out shine a light dowon and line them up with a flat blade screw driver
Old Jul 26, 2015 | 10:14 AM
OLIER's Avatar
OLIER
I Have the same problem on my 2011 street glide...
Wmarketst, Have you find the solution?....
BugBYter
Screamin Eagle CVO Models
Feb 17, 2016 08:22 PM
h0MbrE
May 18, 2015 06:42 PM
Gliden
Jan 2, 2012 04:23 PM
Badbagger
Mar 21, 2010 07:51 PM
jbied
Mar 8, 2009 11:34 PM
