remove/reinstall front tender tip lighting
Old Jan 18, 2015 | 05:34 AM
just plain john's Avatar
just plain john
Default remove/reinstall front tender tip lighting
I have a ding in my front fender. I found an exact replacement from a board member here (thanks Dan!). The fender tip lighting passes through a grommet in the side of the fender, but of course with the lamp socket on one end and a 2 wire disconnect on the other I can't pull it through the hole. I assume I need to disassemble the plug of the disconnect side, right?
Old Jan 18, 2015 | 10:30 AM
mkguitar's Avatar
mkguitar
Remove the wire pins from the plastic connector block.
remember which goes where...usually if both wires are black the + will be marked in some way such as a white stripe or wire gauge impressed into wire
mike
Old Jan 18, 2015 | 10:34 AM
BMFDL's Avatar
BMFDL
Try pushing rubber grommet out plug should go thru.
Bob Z.
Jul 17, 2017 11:22 AM
Booey
Aug 3, 2016 03:23 PM
SecondGear
2014-2024 Touring Models
Mar 31, 2016 07:55 PM
JoeN
Audio Systems
Apr 20, 2014 06:00 PM
01flhtc
General Topics/Tech Tips
Apr 11, 2011 03:39 PM
