General exhaust question
Old Feb 2, 2015 | 08:13 PM
gilbert_roadking's Avatar
gilbert_roadking
Originally Posted by jstrenn
Gilbert Roadking... You should post a picture of your current exhaust system so we could help you determine your current setup. You may already have a nice set of aftermarket mufflers on the bike, and all you need is a set of headers to give you the results your looking for.
You bet - that's a great idea. On the road right now, get back Thursday and will post a pic.
Old Feb 2, 2015 | 08:21 PM
Hausguy's Avatar
Hausguy
I haven't read all of the responses, but what I did was change only the header and kept the stock mufflers on my 2012. I think it sounds good...better than the stock setup but not too loud.
Old Feb 3, 2015 | 05:48 AM
decencyxdefied's Avatar
decencyxdefied
Doesn't seem like he's wanting to do anything major to his bike so no need for a pcv
Old Feb 3, 2015 | 09:20 AM
BigDawgQC's Avatar
BigDawgQC
If you are completely satisfied with your Road King right now, and looking for just a little more bark & rumble from your pipes, just go with a different set of "slip on" pipes. Don't worry about adding fuel management, true duals, headers, air cleaners & all that other stuff right now. You can learn all about that other stuff as you frequent here. Sound is subjective, what you like might be different from what others like. Like some have said here, go down to a dealer on a weekend or a bike night, see what others are running on their tour bikes & listen. Most people on here run Vance & Hines, Rinehart, CFR, Jackpot & Rush Big Louies. I received a lot of compliments on how my Road King sounded with Big Louie's. They are all simple to install, take you thirty minutes.
Old Feb 3, 2015 | 10:34 AM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Originally Posted by gilbert_roadking
Thank you and I like this idea. What is xieds? what is the stage 1 filter?
Sorry - learning
Below is a link on EFI Options. It will help you to understand what the Xied's do for your bike. And also has information on Stage 1. Hope this helps you out
https://www.hdforums.com/forum/ignit...uning-etc.html
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Feb 3, 2015 | 11:33 AM
bigheadted's Avatar
bigheadted
You said you wanted to get rid of the cat right ?? This changes the sound in both tone and loudness. I would do this first.
Many folks I have talked to did the mufflers first then gutted the cats and are not happy because the bike is now too loud.
Several have done the cats first and were happy with stock mufflers.
I have a set of 2013 mufflers I run on my 2004 non-cat bike and they sound good to me.
Old Feb 3, 2015 | 12:03 PM
gilbert_roadking
Thanks everyone for great ideas! I do want to change the sound. If I had mentioned that I wanted to get rid of the catalytic converter that was simply because I thought I had to in order to get a better sound. Is there any real value in removing it or leaving it?
Is the only way to get rid of the catalytic converter to change the header pipes or can it be removed from the existing system?
Thanks again everyone!
Old Feb 3, 2015 | 12:09 PM
decencyxdefied
It can be removed.. Cut the pipe open, remove all the guys, weld it back, there's a company out there that sells stock decated headers for like 350 I think or u can swap yours in and it's 280ish..there was a post about it recently
Old Feb 3, 2015 | 07:20 PM
Tedjay's Avatar
Tedjay
I put HD Street Cannons slip-ons on my 2012 RK with stock head pipes and cat. I'm pleased with the sound so I don't plan on removing the cat.
Old Feb 3, 2015 | 09:35 PM
bigheadted's Avatar
bigheadted
All you need is a cut off wheel on a skilsaw, some drills or chisels and a welder. So easy a hillbilly can do it.
