Tyre gloop
Old Feb 6, 2015 | 11:20 AM
bikehunter's Avatar
bikehunter
Default Tyre gloop
Looking at the thick spoke wheels today and there are some that have air leaking from the rim at some stage of the wheels life.
has any body put in the puncture sealer to combat this possible issue?
Old Feb 6, 2015 | 11:23 AM
TSheff's Avatar
TSheff
Mine had a heavy bonded inner seal so never experienced that. I wouldn't do it though. I carry a can on trips for emergency, but other than that I would never use it.
Old Feb 6, 2015 | 12:10 PM
grbrown's Avatar
grbrown
Question
Are you saying that you currently have those wheels, or are thinking of getting some old chap? If they claim to be spoked, tubeless and air tight there's no such thing! Except on a BMW.....
Old Feb 6, 2015 | 12:36 PM
mkguitar's Avatar
mkguitar
Spoked wheels require inner tubes afaik
mike
Old Feb 6, 2015 | 12:38 PM
grbrown's Avatar
grbrown
Mike,
BMW make tubeless spoked wheels for their GS 'off-road' bikes, however the spokes are set in the rim outside the tyre beads. There are also some custom wheels that claim to be tubeless, with the spokes inside the beads, but.........
Old Feb 6, 2015 | 12:47 PM
KCFLHRC's Avatar
KCFLHRC
Actually the later years 2012 and 2013 Road King Classics were tubeless spokes. So I have been told.
Old Feb 6, 2015 | 12:51 PM
EasTexUltra12's Avatar
EasTexUltra12
Actually my 2012 UC came with tubeless spokes. When it came time for new tires, no one in my town could make the damn things seal. Ended up putting tubes in them. Replaced them with "real" tubeless cast wheels. They're for sale now.
David
Old Feb 6, 2015 | 02:20 PM
Buelligan666's Avatar
Buelligan666
I wouldn't put goop in any tire unless it's off-road use only. If you wanna **** your tire guy off go ahead.
Old Feb 6, 2015 | 03:26 PM
EasternSP's Avatar
EasternSP
Tire sealant really only works on holes in the rubber tire. The bead has to be sealed with tire goop. Kind of a messy job putting it on there and I couldn't rely on a shop to do it right. I had a problem with getting the bead to seal when I was mounting the car tire to my rim. Goop works for the most part, but in cold weather, i.e. below freezing, the goop doesn't hold to good and the air leaks at the bead.
Old Feb 6, 2015 | 04:54 PM
GTK's Avatar
GTK
David
On a Harley tubeless wire wheel you have to replace the inner rim liner anytime you remove and replace a tire.Thats what seals the spokes.
