Bleeding rear brakes
Old Feb 7, 2015 | 04:58 PM
JDSporty's Avatar
JDSporty
Question Bleeding rear brakes
My rear brakes on my 2012 street glide uses a lot of pedal. thought I would bleed the brakes and flush out old brake fluid. Watch a couple of videos on YouTube. I bought a mityvac to do this. Now I got to thinking what about ABS? Is there anything special I have to be concerned with bleeding brakes on abs systems? Certainly don't want to screw this up!
Old Feb 7, 2015 | 06:46 PM
CSMHOG's Avatar
CSMHOG
From what I understand is there's no difference. Harley now requires their Techs to confirm all air has been purged with a Digital Tech II. I'm sure someone with more experience will post in soon. Good luck.
Old Feb 7, 2015 | 06:56 PM
Guntoter's Avatar
Guntoter
Don't let the master cylinder go empty while bleeding and don't turn on the ignition till done and air out of system and you should be ok.
Old Feb 7, 2015 | 06:58 PM
sanman4ever's Avatar
sanman4ever
Screw a speedbleeder into that caliper and be done in about 30 seconds.
Old Feb 7, 2015 | 07:08 PM
qtrracer's Avatar
qtrracer
If the abs pump has a closed reservoir that only is opened up when the pump operates then there will still be old fluid in the system. If flushing the system completely is important to you then you will need to cycle the pump using the dig tech during the flushing operation. If getting most of the fluid is flushed and replaced is sufficient then you can do it your self without the dealer dig tech.
BuddyK
Apr 7, 2019 09:07 PM
stuk4x4
Jun 30, 2018 12:18 PM
pt4u2nv
Apr 18, 2016 09:57 PM
gilbert_roadking
Oct 23, 2015 01:06 PM
rob0225
Oct 13, 2015 12:32 PM
