2011 Road King Classic Cracked Header Pipe :-(
Old Feb 12, 2015 | 07:00 PM
Treif's Avatar
Treif
Default 2011 Road King Classic Cracked Header Pipe :-(
While upgrading my bars I found out that my header pipe has a crack in it. Rather than try to weld it I think I want to replace the header with something more exciting. I already have V&H slip-ons so either true dual or 2 into 2 into 2. I have searched and found good information but nothing that gave me the answers I was looking for.
Old Feb 12, 2015 | 07:15 PM
Florida Swamp Yankee's Avatar
Rear cylinder head pipe? Check all of your supports for adjustment so the pipe isn't carrying all the weight of your mufflers. It was a common thing on '07 +\-
I'm looking at S&S power tune duals, gets the pipes away from my left leg, advertised 8hp gain...
Old Feb 12, 2015 | 09:09 PM
mkguitar's Avatar
mkguitar
What are your questions?
vs stock header- don;t you have a header already?..if so you'll see little difference
mike
Old Feb 12, 2015 | 09:13 PM
mmcbeat's Avatar
mmcbeat
Just curious, but how did you happen to discover an engine problem while you were changing your bars?
Old Feb 12, 2015 | 09:44 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
V/H Power Duals work for me.
Old Feb 12, 2015 | 10:17 PM
texaswiz's Avatar
texaswiz
Ya, that is what popped up in my mind too. There is quite a distance between the bars and the exhaust. Still, it must have happened.
Old Feb 13, 2015 | 09:18 PM
Treif's Avatar
Treif
Default Leak
i said I think there is a leak so when you are working on the bike if you could tighten everything up I would appreciate it. As it turns out my pipe is covered by the HD warranty. So I will take the free replacement for now. I keep adding chrome bits to the bars. Leavers, switches and so on so the total is on the rise.
Old Feb 13, 2015 | 09:21 PM
Treif's Avatar
Treif
Default Correction
its the stock exhaust manifold not a header pipe.
Old Feb 13, 2015 | 09:25 PM
03snake's Avatar
03snake
The stock exhaust manifold is a header pipe.
Old Feb 13, 2015 | 10:03 PM
Treif's Avatar
Treif
Default Pipe
well whatever is stock is broken. But free!
ridedaddy
Nov 22, 2014 11:53 AM
slhanks4
Exhaust System Topics
Apr 2, 2014 02:51 PM
hittman011
Sep 12, 2012 08:20 PM
dnitram
Aug 1, 2011 11:04 PM
