14 street glide wont start
Old Feb 26, 2015 | 04:51 PM
DWC442's Avatar
DWC442
Stage II
Default 14 street glide wont start
Hi I have a 2014 street glide standard it started a few weeks ago like normal I went out tooling around in shed figured I'd start her up for a few turned everything on there was no noise from fuel pump and hit the start switch and got nothing I don't think it's a security thing I tried both FOBs even used the pin every thing else works lights radio ..... it is still under warranty bought new end of may 2014 and has just over 10 thousand miles any help would be appreciated
Thank u
Old Feb 26, 2015 | 05:00 PM
jdunn01's Avatar
jdunn01
you have made sure the Run switch on the right hand handlebar switches is on haven't you?
Old Feb 26, 2015 | 05:02 PM
Kcdcltd's Avatar
Kcdcltd
Check your kill switch.....just a thought. Did that one time on my boat....wouldn't start, loaded it on the trailer....towed it home. Wife had accidently moved the kill toggle switch while cleaning it...started right back up. Just a thought then call your dealer...
Old Feb 26, 2015 | 05:03 PM
8828alex's Avatar
8828alex
check fuel pump fuse if its not the kill switch
DWC442's Avatar
DWC442
Stage II
Yes I've switched it a few times usually when I hit the switch I can hear the fuel kick in but it does nothing
Old Feb 26, 2015 | 05:08 PM
Kcdcltd's Avatar
Kcdcltd
Cant help but think it has something to do with this:To quote a line from a movie, What we have here is a failure to communicate" Sounds like a security issue but just because you get lights may not mean you have enough battery to enable the fuel pump to energize. May want to try your basics....battery and connections. Might have a dead cell....
Old Feb 26, 2015 | 05:13 PM
OldMike's Avatar
OldMike
Do you keep a charger on the bike when stored?
Sounds like your battery is dead.
Old Feb 26, 2015 | 05:32 PM
kryingame's Avatar
kryingame
It's clearly not a dead battery if everything else works.
I have the same problem with my 2012 SG.
You can override the security system if you know your PIN number. This is a problem with some bikes. Basically, uphill need to have your fobs re-tuned to your security system again.
Old Feb 26, 2015 | 05:33 PM
06SGWA's Avatar
06SGWA
I agree. If you don't keep a tender on the battery, this stuff happens. Also, starting the bike periodically and letting it idle is making the problem worse. Most bikes don't produce a charging situation when at idle.
Old Feb 26, 2015 | 05:39 PM
RollaMo's Avatar
RollaMo
Thank u
If the fuel pump isn't even coming on when you turn on the ignition switch (making sure the run/kill switch is also on), then it isn't the security system.
Even without a FOB present, the fuel pump will still energize.
But the starter will not engage.
The OP states he isn't even getting the fuel pump to energize.
